![]() | Home > Maintenance & Modifications > Door Hinge Bolts |
Dora Member Since: 12 May 2015 Location: South East Posts: 170 ![]() ![]() |
I think that depends on model and year, my front doors are but rear doors not!
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543 ![]() ![]() ![]() |
Thanks Dora - sorry model year is 2015
Not sure then, mine is an 11 plate 110xs. I'm sure someone will be able to tell you..
The two bolts that go into the door on each hinge need a 13mm spanner on the back but the ones in the a/b posts have captive nuts. Ray
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello discomog
I don't think the Defender has changed in this area for some time now on my MY 2011 (2.4 Puma) Front Door Hinge M8 Screws are retained by... Captive Nuts Bulkhead Side... ![]() but to answer your question Loose Nuts (will need Spanner) Door Card Side... ![]() Although you can get on these without fully removing the Door Card...Just ![]() JLR OEM Door Hinge Bulkhead M8 Captive Nuts SKIP https://www.defender2.net/forum/topic83242.html |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
You should be able to get a slim spanner in from the side without removing the door card. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
Thanks Jeffersj and others for info. I've had a look (should have done it before!) and have now found a slim open ended spanner that will fit without removing door cards. Cheers.
