Home > Maintenance & Modifications > Door Hinge Bolts
discomog
Door Hinge Bolts
I've searched past posts but cannot find the answer to this simple question. The M8 countersunk setscrews that secure the hinge to the front doors - are they secured by captive nuts? Or will I have to remove the door cards to put a the spanner on the nuts?
Post #428131 2nd Jun 2015 7:25pm
Dora
I think that depends on model and year, my front doors are but rear doors not!
Post #428133 2nd Jun 2015 7:27pm
discomog
Thanks Dora - sorry model year is 2015
Post #428134 2nd Jun 2015 7:28pm
Dora
Not sure then, mine is an 11 plate 110xs. I'm sure someone will be able to tell you..
Post #428137 2nd Jun 2015 7:43pm
mk1collector
The two bolts that go into the door on each hinge need a 13mm spanner on the back but the ones in the a/b posts have captive nuts. Ray
My build thread
Post #428148 2nd Jun 2015 8:29pm
X4SKP
Hello discomog
I don't think the Defender has changed in this area for some time now
on my MY 2011 (2.4 Puma)
Front Door Hinge M8 Screws are retained by...
Captive Nuts Bulkhead Side... Thumbs Up (photo below is of the JLR OEM Captive Nuts
but to answer your question Loose Nuts (will need Spanner) Door Card Side... Sad
Although you can get on these without fully removing the Door Card...Just
JLR OEM Door Hinge Bulkhead M8 Captive Nuts SKIP
Post #428154 2nd Jun 2015 8:34pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
You should be able to get a slim spanner in from the side without removing the door card. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #428270 3rd Jun 2015 8:41am
discomog
Thanks Jeffersj and others for info. I've had a look (should have done it before!) and have now found a slim open ended spanner that will fit without removing door cards. Cheers.
Post #428298 3rd Jun 2015 10:48am
