Home > My Defender > 2002 110 "black" limited edition
Page 7 of 10 <12345678910>
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Well, more good news, the other sill was pretty good too. I guess I caught them in time. So, to celebrate I thought I would treat her to some DRLs. So drilled the holes for the outbound 4x4 ones. I will probably have these holes in my bumper for another 12 months before I fit the lights Rolling Eyes
I test fitted the yrm replacement parts at the weekend. All looked good so all the components are now off being blasted, galvanised and powder coated
I am really missing driving it now though. Realistically it will probably be another month to six weeks off the road Big Cry 2002 110 td5
Post #424614 18th May 2015 9:58pm
mk1collector
It'll be worth it in the end Thumbs Up should last for years!!! Ray
My build thread
Post #424628 18th May 2015 10:27pm
Jimb1978
I collected my parts today, and they have done a top job. And on top of that, they haven't lost any of them!
They just need a good sand to get the drips off and to smooth all the visible surfaces and then a swill with a bit of 'T wash'. They will then be ready for the powder coaters on Monday.
Oh, and all the threads re tapping to clear them of Galv. Big Cry 2002 110 td5
Post #428417 3rd Jun 2015 8:03pm
Jimb1978
It's all starting to come back together now. I can see why Land Rover don't galvanise these parts though. There has been an awful lot of prep work to get a good paint finish. Also, re tapping the captivated nut seat belt mounts was a little unnerving. Fitting the floor went well although I am not convinced powder coating the aluminium was a good idea. It seems to chip very easily. I guess time will tell and if it looks a mess I can always strip and repaint it. 2002 110 td5
Post #429626 8th Jun 2015 10:20pm
Jimb1978
 2002 110 td5
Post #429628 8th Jun 2015 10:23pm
Jimb1978
Sorry about the last picture. It is the right way round on my iPhone but rotates when I upload it 2002 110 td5
Post #429629 8th Jun 2015 10:24pm
mk1collector
Where did you get the galvanising done? And what have you used on the chassis it looks great Thumbs Up keep up the good work!!! Ray
My build thread
Post #429631 8th Jun 2015 10:26pm
Jimb1978
Dinitrol on the chassis. There are a lot of nooks and crannies under there that are impossible to reach with the floor in. Especially on the offside where the fuel and brake lines harbour crud. Metal treat in Bradford did the galvanising. £113 all together. It cost more to have all the parts sand blasted than it did to have them galvanised. They have a very good finish but will still need a good flatting before powder coating as I am considering gloss rather than satin black. 2002 110 td5
Post #429634 8th Jun 2015 10:33pm
Jimb1978
The other sill is now on and the floor back in. Thankfully, the pop rivet holes line up perfectly behind the rear door. It is nice to look at all the stainless steel fixings that have replaced the rusted items....they have been bugging me ever since I bought it, even though they are hidden under carpet!
 2002 110 td5
Post #430102 10th Jun 2015 9:49pm
Jimb1978
Before and after.....
 2002 110 td5
Post #430106 10th Jun 2015 10:03pm
mk1collector
Nearly there Thumbs Up did you put some plastic washers under the stainless fixings to the floor to stop the dreaded dissimilar metal corrosion? Ray
My build thread
Post #430157 11th Jun 2015 8:23am
Jimb1978
No. I gave them a good coating of Duralac though. You can just see it in the photos (it is the yellow stuff). If it starts to look as though it is corroding then I may consider this, although I probably won't own it then! There was very little corrosion there in the first place to be honest.
All the brackets underneath have got foam gaskets between them and the body work. Thumbs Up 2002 110 td5
Post #430178 11th Jun 2015 9:56am
mk1collector
Excellent work, im trying to go through mine with this level of work Thumbs Up Ray
My build thread
Post #430219 11th Jun 2015 1:33pm
SailingTom
Looking good, few bits I might have to do on mine. Definitely will follow your example going down the galvanized route.
Yours is certainly a well thought out 110 Thumbs Up
Post #430239 11th Jun 2015 2:33pm
Jimb1978
She is all back together now and passed her mot yesterday.
I had some floor bolts and clips left over so decided to make myself some mud guards to protect the DRLs
 2002 110 td5
Post #431451 16th Jun 2015 9:05pm
