Home > My Defender > 2002 110 "black" limited edition
Page 5 of 10 <12345678910>
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Fame at last.....I made the local paper.
I did wonder why a man with a very expensive looking camera was stood in milnsbridge in the middle of the pouring rain taking random pictures.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2002 110 td5
Post #336964 9th Jun 2014 6:30pm
Jimb1978
Thought it was about time I shared my camping kitchen. I have been using this for around 18 months now and it works very well.
A def2 member called Chopcat motivated dm to build this with his excellent trailer build.
I took a lot of my ideas from Drifta...an Australian manufacturer who specialise in this type of stuff. After browsing their website I figured I could build something similar...and so the research started.
Brackets, handles, latches, telescopic tube, Formica, protective cappings. It took hours to find the right stuff.
It slides out the back of the DC
I can then put one set of legs on whilst it rests on the tailgate, then put it on the ground and insert the others.
The front panel detaches and forms the support for the working surface, which swings open from the top.
It has a drawer and a pull out shelf for a washing up bowl. The dimensions are based around a Coleman petrol stove and all our camping utensils fit inside. The only other thing we use is a Cobb.
Anyway, we are leaving for the Auvergne region of France on Monday and look forward to using it properly again this year.
Just to add, I still haven't managed to build my 'patriot cage' copy yet but it is on the list!
Post #347629 25th Jul 2014 10:42pm
mk1collector
Looks great Thumbs Up have a great holiday!
Ray
Post #347639 25th Jul 2014 11:49pm
Jimb1978
Cheers Ray.
She is now all packed for a great overland journey...you know the stuff, ground anchors, sand ladders, boil in a bag food, water purification.....if only!!
The realities of family camping are slightly different, nappies, bottles, toys and more "stuff" appearing last minute from the house. Big Cry
Maybe one day 2002 110 td5
Post #347993 28th Jul 2014 9:28am
Jimb1978
I have finally recovered from the cost of a new gearbox so have restarted the modding!
Nothing major but something that has been bugging me since I bought it. The previous owner had cut off the middle leg of my roof rack in order to fit it around the windscreen protector, which meant the rails were not spreading the weight as they should...well, at all really. So I bought a roof bar designed for roll cages from safety devices, and immediately cut it in half with an angle grinder. Big Cry
It was designed to clamp to the middle diagonal tubes of a roll cage and my configuration only has the horizontals directly above the doors. I had to extend it by nearly 6 inches and alter the angles of the brackets to suit the new horizontal position it was going to sit in.
Anyway, pictures paint a 1000 words:
 2002 110 td5
Post #379315 15th Dec 2014 10:55pm
mk1collector
Top work Thumbs Up
Post #379404 16th Dec 2014 2:14pm
Jimb1978
Cheers,
I just need to find a good aluminium welder now to reweld the originals back in further back, behind the windscreen protector to spread the weight on the rear leg.
Any ideas? 2002 110 td5
Post #379409 16th Dec 2014 2:29pm
mk1collector
Not off the top of my head as I've never had any Ali welded but I'll ask around Thumbs Up
Post #379422 16th Dec 2014 3:44pm
Jimb1978
My security cage is now back from powder coating so it is time to share it with you all. I really liked the idea of the patriot cage but could not justify the expense, so I decided to make my own.
With the cost of workshop consumables and powder coating included I managed to build it for bang on £200, which compared to the £650 patriot I didn't think was too bad.
 2002 110 td5
Post #413534 3rd Apr 2015 4:55pm
Jimb1978
The only drilling to the vehicle were four holes in the bottom of each hoop leg and two rivnuts fitted either side of the tailgate for the door opening.
There is a shelf to fit half way up. When I have made the wooden late and fitted them I will post some more pictures.
Thanks for looking
 2002 110 td5
Post #413536 3rd Apr 2015 5:00pm
mk1collector
Excellent work as ever Thumbs Up where did you go for the powder Coating and did you find someone to do the Ali welding on the roof rack?
Ray
Post #413554 3rd Apr 2015 6:34pm
Jimb1978
i used Crimble for the powder coating. I dropped it off yesterday at about 1500 and he phoned me at 0830 this morning to say it was done. Top job, all for £50! They put on the zinc base coat as well, unlike many powder coaters, he informed me.
I still haven't got around to finding anyone for the ali welding. A mate of mine has a really good Tig welder but I would be relying on him to do it because I am not practised enough at Tig welding aluminium...and he is always really busy...and not too bothered about how things "look"! Especially when he is rushing. He has recommended somewhere in slaithwaite, or Marsden...can't quite remember, so I might give them a call.
Fitted the ARB yet? 2002 110 td5
Post #413560 3rd Apr 2015 6:43pm
mk1collector
I use crimble for all my powder coating and never had a problem yet Thumbs Up I asked around but no one knew any recommended Ali welders Big Cry my front arb is on but haven't got the rear bushes and brackets yet so hopefully in the next couple of weeks and I'll try and get my new springs on too Mr. Green
Post #413565 3rd Apr 2015 6:58pm
SailingTom
Looks really good.
Im hoping my roof rack will fit behind the roll hoop but will see tomorrow!
Love the layout of your rear stowage aswell, very well thought out
Post #413801 4th Apr 2015 7:00pm
Jimb1978
Cheers sailingtom!
Just had a nosey in your gallery. It makes me want to put mine in the body shop...yours is mint! Thumbs Up 2002 110 td5
Post #413828 4th Apr 2015 9:26pm
