Home > Maintenance & Modifications > Mud New Convex Mirror
Page 2 of 3 <123>
CLCraig
United Kingdom 2015 Defender 90 Puma 2.2 HT Stornoway Grey
Has anyone got a picture of them fitted? Many thanks?
Post #421410 5th May 2015 8:32pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
munch90 wrote:
Sure you not got it on wrong side , they do left and right ones on muds website , just a thought ?
Sensible question but no, correctly fitted.
Sent it back for a refund now. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #421691 6th May 2015 9:29pm
trooper
United Kingdom 2002 Defender 90 Td5 HT Tamar Blue
Have just purchased a set (LH/RH) of the larger mirrors but cannot undo the existing mirror screws as they are seized solid. Don't want to damage the existing mirrors trying to remove the screws, as I may not like the larger mirrors when fitted, any suggestions how I may remove them would be greatly appreciated!
Post #421744 7th May 2015 9:42am
You could buy a pair of replacement arms, and leave the old mirrors alone on the old arms.
Non-genuine or take-off arms are not expensive.
Post #421789 7th May 2015 12:52pm
smb
Here you go, Not the best, but gives you an idea
[/img]
Post #422613 11th May 2015 12:28pm
gilarion
Love the Pipe holder. Cool For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #422634 11th May 2015 1:28pm
CLCraig
Thank you. They don't look out of place at all thought they would be far too big
Post #422637 11th May 2015 1:35pm
smb
Thanks, the only 'real' accessory needed!! Cool
Post #422640 11th May 2015 1:42pm
smb
They're not as big as a lot of people will have you believe. At least I can now spot the audi/bmw Censored before they try and cut me up Thumbs Up
Post #422642 11th May 2015 1:43pm
X4SKP
Hello All
Interesting...
I am looking at this for a different reason... Shocked
Have recently bought an Eriba Van at 2M wide and have a need to ensure that I comply to the Rear Viewing Requirements, my initial thoughts were to swap over my existing mirrors onto a pair of Extend Arms.
The Defender is approx' 1755mm wide, between the inside edges of the Standard Door Mirrors
and the Mirrors themselves are approx' 125mm wide.
So the overall width of the Standard Mirrors are under 2M
1950mm in my case with the mirrors angled in to suite my needs.
For Towing the law states that for cars registered after 26th January 2007, towing mirrors must not project more than 250mm beyond the width of the Caravan (Trailer), so in my case the overall 'extended' door mirror width of 2500mm is allowed. (Eriba + 500mm)
Whilst I know the Mud Blind Spot Mirrors are not designed as Towing Mirrors, they may still be of interest to give an increased Rear and Blind Spot View, probably still in conjunction with using the Extended Mirror Arms.
Having now sorted out my towing frame I will set up and see how much of the Blue Triangle I get with the standard set up and work out a route to get all of it (or more).
Main wish (beyond compliance) is to have a 'solid' set up, swapping over Arms is doable but there's more to when you actually look at it, Door Security on the top door hinge for a start in order to get to the Door Mirror Arm mounting screws
Any thoughts, those who have sorted out there own set up... Question
Towing Mirror View Requirements
2M wide Eriba 540 GT SKIP
Post #422651 11th May 2015 2:39pm
munch90
take it you have tried with standard mirrors and measured what you can see ?
Post #422652 11th May 2015 2:54pm
X4SKP
Hi munch90
No just about to, dragged this home with both the wrong towing arrangement (ball too high)
and no adjustment to mirrors, but felt that the standard set up didn't restrict my view.
Want to ensure that I avoid the 3 points on my clean license though... Exclamation (and a fine)
 SKIP
Post #422655 11th May 2015 3:14pm
Cupboard
The blind spots in my 110 Hardtop are large enough I lost our entire combine header and a trailer somewhere off to the passenger side yesterday. It's a good thing I knew it was there because if I'd just been relying on what I could see in mirrors we'd have had a bit of a crunch.
Post #422867 12th May 2015 12:57pm
HardCharger
[/img]
Hmm... After seeing these, they're apparently not as big as I thought they'd be. Looking forward to seeing one live before final decision.
Post #423364 14th May 2015 5:38am
CLCraig
That was what was stopping me getting some but they don't look stupid from this pictures at all
Post #423375 14th May 2015 7:41am
Page 2 of 3 <123>
