Home > Puma (Tdci) > Air box mod help please.
Page 2 of 5 <12345>
Anderzander
What have people done to seal the two little holes that are exposed when the separator is removed ?
Post #418545 24th Apr 2015 7:10am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Gaffer tape.
Short term solution, might have to come up with something more permanent.
Post #418558 24th Apr 2015 8:02am
Davie L
Scotland 2008 Defender 90 Puma 2.4 HT Orkney Grey
Ok thats breat, So the general thoughts are its worth doimg and certinally does help the engine breathe little easier.
Now how do i do it, Anyone got photographs etc so i can see how yous have done it?
Davie
Post #418584 24th Apr 2015 9:31am
Here's the view from above:
and looking backwards down the intake to the cyclone:
From the 2nd photo, it's easy to see how it restricts the air flow, but then it is a deceptive angle.
Post #419468 27th Apr 2015 4:23pm
Cheshire110
i don't get this?
surely theres no way that the plastic is more of a resistance to the air flow than the air filter itself?
or do you remove the air filter too? Cheers, David
Post #419469 27th Apr 2015 4:28pm
munch90
I would be worried about the filter getting damp/wet after removal of the fan separator , your get a lot more restriction from a damp/wet filter
as said before ive seen filters sucked up towards the engine intake because filters have got damp
no leave filter in , there not a bad restriction
Post #419471 27th Apr 2015 4:34pm
Out of interest does anyone know what this refers to:
is it the cyclone?
It's moulded into the inside of the the air box lid:
Post #419479 27th Apr 2015 4:56pm
Anderzander
If moisture on the filter was a problem - then surely every car that doesn't have a cyclone would have a problem ? And loads of cars don't have them.
Post #419487 27th Apr 2015 5:06pm
K9F
Not at all....Not everyones filter intake is on the exposed outside of a vehicle behind the front wheels though. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #419488 27th Apr 2015 5:09pm
munch90
maybe the defender during testing did have a problem due to where the intake is
maybe its in case of if a lot of water went down intake may help prevent to much getting to engine
maybe its for heavy rain
very hard to say without testing
but a damp/wet filter will restrict air flow , like said I have seen it many times on all makes and even seen where the rubber seal has pulled out of the groove round the airbox allowing air passed the filter
the cyclone is there for a reason , you can see the marks on them in some the pics where the flow of air has left tracks on the blades
Post #419494 27th Apr 2015 5:20pm
Anderzander
That's a fair point k9F - although I never remember it being an issue for any of the unfaired motorcycles I rode.
The received wisdom being that the water atomised with the air and passed through the the filter.
I guess I haven't made my mind up yet and not heard anything that has really convinced me.
Post #419513 27th Apr 2015 6:12pm
I've done the airbox mod, no problems at all. There is a drain hole in the bottom anyway.
Moist air will get through regardless and rain it's self cannot get there without hitting the sides and if much does get in it'll acumulate and out the drain hole.
If you had a Snorkel and blocked up the drain hole too it might be an issue though but there is a rain separator built into those too.
It allows more air in quicker with out being a resistance in the system.
Saying it's there for a reason is not always true in every case.
LR don't have tuning as standard and it's better.
The standard exhaust has a hefty centre silencer but with out is better.
Then there are EGR's etc which are better shut off
The intake being on the side has no air ram effect so nothing can be driven in there as you don't drive sideways. Whistle Rolling with laughter
Dust is much more of an enemy and most certainly you don't want to run with out a filter in. Loads of rubbish gets in the bottom the airbox of which if it wasn't for the filer it'd be straight in.
Post #419518 27th Apr 2015 6:22pm
Anderzander
Steve - what did you do with the holes exposed when you removed it ?
Post #419521 27th Apr 2015 6:34pm
Do you mean the drain hole(s) ?
Post #419535 27th Apr 2015 7:03pm
Anderzander
No - the little holes that are exposed part way around the circumference of where the hydro clone locates.
I don't have any pics to hand Im afraid.
Post #419553 27th Apr 2015 7:46pm
Page 2 of 5 <12345>
