Home > Maintenance & Modifications > Spare wheel lock
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 4 of 9 <123456789>
nitram17
As long as it works an is not powder coated im in!
Post #411308 27th Mar 2015 1:39am
nakatanenga
Germany
will be available in plain stainless steel and powdercoated black. WANTED:
SII or SIII in max 1.5k
Post #411343 27th Mar 2015 9:35am
jens_1967
Germany 2013 Defender 110 Puma 2.2 SW Keswick Green
i am interested too
Post #415662 12th Apr 2015 12:56pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Interested,
Pplease advise when available from Brendan - thanks Smile
Post #415684 12th Apr 2015 2:01pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
As a few people have shown an interest, I've taken a few photos of the install. All in all an easy job to do.
The template supplied negates the need to do any measuring.
Holes drilled and a dab of paint added to stop any corrosion.
Stub all bolted on. This was a test fit. I had to add an extra washer as it was all a bit too tight (5 washers used in total)
And all fitted up.
Gap between tyre and wiper blade.
Overall I'm impressed with the lock. Easy to fit, good looking and pretty cheap.
One issue I've got is that although 4 spacer washers was too tight, using 5 washers leaves it all a bit loose. This results in a bit of rattling when you shut the rear door.
If you could use the wheel spaces fitted on the studs as standard then this wouldn't be an issue as you could just adjust the wheel spacers to tighten it up. However you'd need a whole load of washers to be able to use them. This will also be an issue when I get a spare to match the 285/75/16s fitted to the other wheels. My plan is to knock up a couple of discs of steel to slide in instead of the washers used to space the lock.
All in all a good product just let down by minor design issues. Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #417105 18th Apr 2015 6:22pm
mikeh
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Thanks for that Tom. Need to get round to doing mine
Could you put a foam pad or rubber washer between the disc and wheel to stop the rattle?
Mike
Post #417110 18th Apr 2015 6:46pm
munch90
Cant knock that , looks ok
Post #417114 18th Apr 2015 7:05pm
TDCi Guy
Good idea that Mike. If you stuck a foam backing to the disc that should stop it all from rattling around. I'll give that a try if I can find some foam. Tom
@tditomprice
Post #417241 19th Apr 2015 1:54pm
Merlin
Will it fit with a swing-away wheel carrier?
Merlin
Post #417678 20th Apr 2015 7:18pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Depends on the carrier
I have the Nakatanenga carrier (NOT stainless) and I don't think it will fit (or very tight squeeze)
The bit the plate is welded to is where the holes for the bottom two bolts should be
I bought the lock to see if ti would fit Crying or Very sad
Post #417681 20th Apr 2015 7:25pm
K9F
Certainly wouldn't fit on a Safari due to the head attachment.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #417691 20th Apr 2015 7:56pm
kmac
How's this coming along Peter?
Post #419162 26th Apr 2015 2:45pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Spare Wheel Lock
Any news from Peter, or Brendan possibly?
Post #423417 14th May 2015 10:25am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Nakatanenga Lock - Any news from Peter, or Brendan possibly? NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #453175 7th Sep 2015 9:40pm
nakatanenga
Germany
Here the pics of the prototype. No drilling required, adjustable = fits all wheels, 3mm stainless steel construction
 WANTED:
Post #458936 29th Sep 2015 12:27pm
This topic is locked: you cannot edit posts or make replies.  Back to top
