Home > Maintenance & Modifications > Spare wheel lock
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 2 of 9 <123456789>
TJ101
TJ101 wrote:
?? and 18" Bowlers Question
i am in then please California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #410818 25th Mar 2015 4:57pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Interested Thumbs Up Cogito ergo sum
Post #410822 25th Mar 2015 5:07pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Also interested if it's black, will take 18" boosts ... fitted with 275/65 tyres ... mounted on a swing away wheel carrier ... and I can get a wheel cover over it.
Post #410845 25th Mar 2015 6:07pm
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
Interested Defender Td5 XS90
Post #410848 25th Mar 2015 6:23pm
Tonyrec
I'm interested
Post #410889 25th Mar 2015 8:05pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
So:
1. Bolt goes through wheel carrier, fixed with locking nut.
2. Other end the shovel bracket is bolted on. By turning it always fits, regardless of tyre width.
3. The three eyes (1+2) is to put a padlock through>
May move it to one side and put some kind of clasp on the other side.
As the shovel goes vertically over the tyre, it makes removing the tyre very hard.
But this is basically my idea.
Post #410911 25th Mar 2015 8:46pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Just bought the lock on ebay. Looks like a great bit of kit! Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #410959 25th Mar 2015 10:22pm
nitram17
nakatanenga wrote:
Any wheel as long it has a hole in the middle and a pattern of 5x165.1
Sounds like your on a winner naka......fair price for a fair product and you have an order from me!Get the pricing wrong and I can see the tumbleweed from here! Thumbs Up
Post #410962 25th Mar 2015 10:33pm
K9F
Whilst Nakatanenga have an excellent reputation and contract manufacturers to provide their services, apart from an 'idea' there is not much more apart from the fact it will be made from stainless. I like stainless. I too would like to register an 'interest' in that 'idea' and await with eagerness to see if it will be 'universal' enough to include swing away carriers as requested previously and to see the final product. How long can we expect to wait please?
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #410990 25th Mar 2015 11:30pm
nakatanenga
Germany
The idea is ready, the drawing nearly ready Will have the prototype in about 2-3 weeks.
The ebay offer is OK but only usable with boost wheels and you have to drill (and weaken) the wheelcarrier. As far as i can judge from here it will not work with swing aways. WANTED:
SII or SIII in max 1.5k
Post #411035 26th Mar 2015 9:16am
munch90
gklau wrote:
Yes!
Would be interested. Not keen on drilling through my spare wheel carrier. Can you make one in black to match my wheel?
why worry about drilling the spare wheel carrier , its a bolt on item and if you ever wanted to go back to standard you can pick up another carrier for about 20 quid from 4x4 jumbles etc
Post #411037 26th Mar 2015 9:21am
nakatanenga
Germany
Its too weak anyways. Have had a couple of broken ones already. Always arounf the 3 wheelstuds or around the bolts which fix the carrier on the door. If additionally weakened by holes it will break even faster. WANTED:
Post #411038 26th Mar 2015 9:24am
@Peter - Nakatenga
I, like many others I'm sure, are now terrified that our standard wheel carriers are going to fall off the back door having ripped six holes in the back door or ripped three welded bolts out of the wheel carrier
Could you post up pictures of the many failures you've encountered please and explain in more detail how three 10mm holes in the centre of a 6" x 8" steel plate that is 3mm thick will speed up this process ?
Also, in your vast experience, what can we do to stop this happening (apart from buy one of your wheel carriers of course)
Thank you Bow down
Post #411043 26th Mar 2015 9:38am
munch90
and the fact that your bolting a piece of thicker stainless steel using the holes you have drilled
Post #411045 26th Mar 2015 9:47am
nakatanenga
Germany
Haven't got any pictures here. Will check the pile of demountet OE carriers later, but the broken ones are usually binned in the big blue container...
From the engeneering point of view the material will be weakened. There is enough material available on the web about these facts. Maybee it won't be weakened enough to have an effect. WANTED:
Post #411061 26th Mar 2015 11:15am
This topic is locked: you cannot edit posts or make replies.  Back to top
