Home > Maintenance & Modifications > Difflock drain plug
Page 3 of 5 <12345>
gilarion
Great piece of kit, but, BEWARE!
I recently fitted one and recently had the Defender serviced at a well know Land Ranger independent Land Rover garage, and the mentally challenged mechanic Whistle (I had my doubts about him when I saw him eating a spaghetti hoop sandwich cold!).
Why BEWARE, because even though I told the mechanic about the Difflock plug and gave him the flexible pipe the moron unscrewed the Difflock from the sump as you would an ordinary sump plug to drain the oil. Rolling Eyes
I was not to pleased and even the other mechanics called him a few choice words.
I usually drain the oil myself but as it was due a full service I did not bother this time.
Post #395138 2nd Feb 2015 2:47pm
MartinK
excossack wrote:
They are a nice bit of kit, I like mine.
With the amount people buying them, would it be worth doing a group buy?
Great idea...too late for me tho Crying or Very sad
Name and shame so we can avoid Rolling Eyes Whistle Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #395151 2nd Feb 2015 3:52pm
gilarion
Clwyd
Post #395164 2nd Feb 2015 5:16pm
MartinK
Just arrived from Femco UK http://www.drainplug.co.uk/
Awesome service, only placed the order yesterday Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #395462 3rd Feb 2015 3:36pm
gilarion
If only all companies were so prompt with delivery. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #395464 3rd Feb 2015 3:38pm
MartinK
Yes- came with a 24-hour courier...and they only charged £2.50 carriage Exclamation Thumbs Up Mr. Green Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #395465 3rd Feb 2015 3:41pm
Kitoper
Switzerland
Does anyone know which plug and size would be needed for a 2013 2.2 Puma?
Thanks in advance
Post #395467 3rd Feb 2015 3:47pm
MartinK
Kitoper
On the Femco UK website ( http://www.drainplug.co.uk/ ) - there's a enquiries form (in "enquiries") - they'll spec-up the kit you need Thumbs Up
I think you need the same as me (TDCi's are all the same drain plug)?
At least then if it's wrong, they'll be duty-bound to replace it Whistle Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #395481 3rd Feb 2015 4:56pm
Kitoper
Switzerland
Thank you Martin - I will share what I find Thumbs Up
Post #395484 3rd Feb 2015 5:14pm
donmacn
Ooooh, this is an old thread!
But... I've just changed the sump on my 300tdi. The old sump had a drain plug on it, like this:
It's been on the car for at least the 17 years that I've had it, possibly the whole 24 years the car's been around, and given no trouble, so I was going to refit it. Unfortunately the hole on the new sump is a larger diameter (15mm spanner) so it won't fit. I had to resort to the standard plug to get going again.
I could get another valve like that. I think they are about £25 or I could go for one of the femco/difflock ones.
On the face of it, the femco one seems more robust/less likely to get knocked if off-road. But this one is so easy to use - just slide on a short length of hose; turn the tap; watch the oil drain into the container. Very controllable.
Anyone used both and able to give any either/or experience?
With the femco/difflock ones, is it the screwing in of the hose that opens the tap?
Thanks Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #748962 3rd Jan 2019 7:53pm
excossack
Correct - If you really want I can wander to the shed and take a pic of the brass hose end (the bit you see in MartinK's post) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #748968 3rd Jan 2019 8:29pm
donmacn
Thanks for that - no need to get out the camera! I also searched for 'Stahlbus' ones, similar to the femco ones, and they had a diagram showing how it worked.
Despite the fact that I've had no problems with the femoto one for so many years, the femco/difflock one does seem more robust.
Still interested in anyone's long term experience of them. Donald
in the past..
Post #748973 3rd Jan 2019 8:45pm
excossack
Mine has been in for 8 years or so. No issues and makes changing oil much easier. Ideal if you accidentally add too much oil and need to drain some off. 1999 Defender TD5 110
Regards
John M0VAZ
Post #748977 3rd Jan 2019 8:58pm
Litch
I have had one on my 2004 300TDi since the first (1000 mile) service, never had a moments problem with it.
Fitted one to my wife's Freelander 1 TD4 about 8-years ago, that also has been faultless.
Both used twice yearly. ONE LIFE, GET IT!
Post #748990 3rd Jan 2019 9:33pm
donmacn
I guess that will do it for me then. I'll get one ordered and fit it at the next oil change.
Thanks both. Donald
in the past..
Post #749001 3rd Jan 2019 9:53pm
Page 3 of 5 <12345>
