![]() | Home > Maintenance & Modifications > Difflock drain plug |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Great idea...too late for me tho
Name and shame so we can avoid |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142
Clwyd |
Just arrived from Femco UK http://www.drainplug.co.uk/
Click image to enlarge Awesome service, only placed the order yesterday |
If only all companies were so prompt with delivery. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Yes- came with a 24-hour courier...and they only charged £2.50 carriage
| Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204
Does anyone know which plug and size would be needed for a 2013 2.2 Puma?
Thanks in advance |
Kitoper
On the Femco UK website ( http://www.drainplug.co.uk/ ) - there's a enquiries form (in "enquiries") - they'll spec-up the kit you need I think you need the same as me (TDCi's are all the same drain plug)? At least then if it's wrong, they'll be duty-bound to replace it |
Thank you Martin - I will share what I find
| donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1917
Ooooh, this is an old thread!
But... I've just changed the sump on my 300tdi. The old sump had a drain plug on it, like this: It's been on the car for at least the 17 years that I've had it, possibly the whole 24 years the car's been around, and given no trouble, so I was going to refit it. Unfortunately the hole on the new sump is a larger diameter (15mm spanner) so it won't fit. I had to resort to the standard plug to get going again. I could get another valve like that. I think they are about £25 or I could go for one of the femco/difflock ones. On the face of it, the femco one seems more robust/less likely to get knocked if off-road. But this one is so easy to use - just slide on a short length of hose; turn the tap; watch the oil drain into the container. Very controllable. Anyone used both and able to give any either/or experience? With the femco/difflock ones, is it the screwing in of the hose that opens the tap? Thanks Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
Correct - If you really want I can wander to the shed and take a pic of the brass hose end (the bit you see in MartinK's post) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Thanks for that - no need to get out the camera! I also searched for 'Stahlbus' ones, similar to the femco ones, and they had a diagram showing how it worked.
Despite the fact that I've had no problems with the femoto one for so many years, the femco/difflock one does seem more robust. Still interested in anyone's long term experience of them. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Mine has been in for 8 years or so. No issues and makes changing oil much easier. Ideal if you accidentally add too much oil and need to drain some off. 1999 Defender TD5 110
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
I have had one on my 2004 300TDi since the first (1000 mile) service, never had a moments problem with it.
Fitted one to my wife's Freelander 1 TD4 about 8-years ago, that also has been faultless. Both used twice yearly. ONE LIFE, GET IT! |
I guess that will do it for me then. I'll get one ordered and fit it at the next oil change.
Thanks both. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| All times are GMT |
