![]() | Home > Puma (Tdci) > Puma fuel bleeding pump |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
I've been thinking about the 310-110 SPX special tool for bleeding the TDCi fuel line. From the wire diagram (previously posted) it looks to be:
1. 2 Special clamps to fuel line 2. Flexible hose 3. Rubber hand pump (as used on outboard fuel tanks etc) 4. Relief Valve. I'm assuming the relief valve is just a screw down one way valve to purge the air. This can't be a very difficult thing to fabricate, I also understand there is a clear section of tube around the relief valve. Has anyone got one of these pumps they can post a pic of? Does anyone know the specifics of the quick release clamps on the fuel line? They've got to be an aftermarket part, surely! 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I just called Land Rover South Africa again and they tell me that the pump is not for sale other than to dealerships.
They say that it is only made for such and not for sale to the public. I asked him what hapens if you need one out in the bush and he said there are plenty dealers througout Africa "so call your nearest dealer" ![]() Gues I will have to wait for answeres to your post and make my own. Puma 110 - gone Series III 1973 - going strong |
I also drained out bout 100cc of fuel at the drain and not problems so maybe we are worrying for nothing and should just fill the filter with fuel and screw it back in carefully.
Anyone want to do a practice run ![]() I would hate to cause damage to the pump. This is a pic I just took of the pump ![]() ![]() Series III 1973 - going strong |
It may well be nothing but from what I've read about Transits replacing the filter can leave an air block. I suspect this may also apply to the Puma as the system doesn't seem to be highly pressurised. For piece of mind I think I'll make up a bleed pump. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
As I am off to Morocco next month. I have just visited my dealer to discuss a number issues I may have whilst out there. Replacing the fuel filter was one of them. The tool is available in the UK. I am waiting for my local tool supply company to get back to me with some options. Sealey Tools do the pump bit as mentioned Part No VSE055.
The tool No is 310-163 its available at a cost of �165 + Vat at 17.5% and postage to a UK address for �8
![]() ![]() Tomorrow I am taking a trip to my local technical hose supplier with the tool 310-163 that I have on loan from my dealer. Hopefully we will be able to identify the ends and get this sorted ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Are we sure that it is even needed? Mike
I posted for interest on the Transit forum and one guy confirmed you just need to fill the filter with diesel before you install and no problems.
Maybe the tool is used when you completely run out of juice and all the pipelines are empty and no suction on the pump. I am sure one small air bubble won't be a big issue. Rgds James Puma 110 - gone Series III 1973 - going strong |
�165 !!!!! Holy *&%$... That's AU$370 ![]() Can you take some nice detailed pics of the loan tool and post them up or e-mail them????? 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Will do ![]() The instructions state that the bleed tool should be connected in line between the tank pick up pipe and the fuel pump. Then when the fuel is drawn up to the pump you disconnect the bleed tool and replace the pick-up pipe onto the pump. Which in my opinion will allow air into the fuel system ![]() ![]() ![]() I will report back soon ![]() |
The home made one works
![]() Removed and drained the filter. Here is the contents ![]() ![]() This is the pump I made. As you can see there is only one connection on the 'tool' as I never connected the bleed tool in line. I simply placed the end of the pipe into a container to catch the fuel as it was pumped through. The other end was pushed into the female connector of the fuel line. It took about 2 minutes and about 2 pints of fuel before the fuel became air free. ![]() Here is the Land Rover tool ![]() A picture with dimensions of the male end of the Land Rover tool. ![]() A picture with dimensions of the male end of the home made tool. As you can see its smaller in diameter but it sealed. Obviously I would like to get an end that is the correct � ![]() This is the location of the connector that the bleed tool fixes to. Push the blue tabs in and pull the connector off the feed to the fuel pump. ![]() Disclaimer If you ![]() ![]() ![]() |
was the black fitting a standard item or did you machine down a plastic swage nipple on one end?
If it was standard - does it have a name? Thanks James Puma 110 - gone Series III 1973 - going strong |
