![]() | Home > Puma (Tdci) > 2nd gear squeaking |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Only in 2nd high on the road, have you tried to replicate it inn 2nd low? Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| willinone Member Since: 25 Feb 2014 Location: Essex Posts: 20
yep, both in low and high. starting to sound like a horse neighing!
Hmmm, interesting. If it's still under warranty I'd be talking to my dealer. If you want to investigate yourself I'd checking transmission oils, propshafts then belts etc but the fact that it only happens in 2nd when cold is a bit of a puzzler. Steve.
Went back this morning and apparently they couldn't find anything wrong with it.
Let's see what happens.......... |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
if you press clutch on over run in 2nd gear does noise go ?
yeah it does go
| Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 436
this can be the clutch release bearing, have you been wading!
ahem...yes
| All times are GMT |
