|  | Home > Puma (Tdci) > 2nd gear squeaking |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472      | Only in 2nd high on the road, have you tried to replicate it inn 2nd low? Steve.
 Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. | ||
|  28th Apr 2014 8:21pm |
| willinone Member Since: 25 Feb 2014 Location: Essex Posts: 20      | yep, both in low and high.  starting to sound like a horse neighing! | ||
|  30th Apr 2014 6:45am |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472      | Hmmm, interesting. If it's still under warranty I'd be talking to my dealer. If you want to investigate yourself I'd checking transmission oils, propshafts then belts etc but the fact that it only happens in 2nd when cold is a bit of a puzzler. Steve.
|  30th Apr 2014 8:27pm |
| willinone Member Since: 25 Feb 2014 Location: Essex Posts: 20      | Went back this morning and apparently they couldn't find anything wrong with it.     Let's see what happens..........  | ||
|  27th May 2014 9:30pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | if you press clutch on over run in 2nd gear does noise go ? | ||
|  27th May 2014 9:53pm |
| willinone Member Since: 25 Feb 2014 Location: Essex Posts: 20      | yeah it does go | ||
|  28th May 2014 6:15am |
| Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 436      | this can be the clutch release bearing, have you been wading!     | ||
|  2nd Sep 2014 2:44pm |
| willinone Member Since: 25 Feb 2014 Location: Essex Posts: 20      | ahem...yes    | ||
|  2nd Sep 2014 4:30pm |
| Posting Rules
