![]() | Home > Puma (Tdci) > 2nd gear squeaking |
Only in 2nd high on the road, have you tried to replicate it inn 2nd low? Steve.
willinone Member Since: 25 Feb 2014 Location: Essex Posts: 20 ![]() ![]() ![]() |
yep, both in low and high. starting to sound like a horse neighing!
Hmmm, interesting. If it's still under warranty I'd be talking to my dealer. If you want to investigate yourself I'd checking transmission oils, propshafts then belts etc but the fact that it only happens in 2nd when cold is a bit of a puzzler. Steve.
Went back this morning and apparently they couldn't find anything wrong with it.
![]() Let's see what happens.......... ![]() |
if you press clutch on over run in 2nd gear does noise go ?
yeah it does go
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 435 ![]() ![]() ![]() |
this can be the clutch release bearing, have you been wading!
ahem...yes
