![]() | Home > Puma (Tdci) > Puma re map - very pleased |
Cheers Steve all sorted mate
![]() Had the problem before the d cat went on NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2471 ![]() ![]() ![]() |
limiter free. Usually my top speed is about 110km/h. The chip is good going uphill at high elevations. Puma 110" SW ............................................................. Earth first. Other planets later |
Thanks MK Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
What�s the point in driving around with a strangled cat under the bonnet, unleash the beast. For example if you buy a VW golf you get to choose from 90, 100, 110, 130 etc horsepower depending on how much more money you want to spend, this is all achieved in VW standard software. Remap companies are simply giving us the option to go to the next stage and so on. I'm not one for jeopardising reliability for some more horses and I don�t think for one minute I have done that. I also think you could push things too far and end up breaking bits for the sake of more power. You asked a good question and hope you can respect a good answer ![]() 1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Hello
I read this thread and I think that the answer to my question is not in it ... ![]() Is there a limit to hom many times the ecu can be programmed and re-programmed? For example: I install my remap ... and next week I suddenly have to go to the dealer for some reason, I remove the remap to standard (they won't notice do they?) ... when I get the car I install my remap again ... In a few months I have to take the car to the dealer for some other reason, I remove the remap and when I get the car i install the remap again ... Is there a limit to how many times I can do this ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
niglyn Member Since: 12 Jun 2009 Location: Surrey Posts: 82 ![]() ![]() ![]() |
All programmable ICs have a finite number of times they can be re-programmed. I have no idea what chip is used in our LRs, so cannot look up the specs, however most programmable ICs in the electronics world quote re-programming of over 1000 times, so I don't think we need worry.
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
This is my first post and have been following for a while, Pete fitted a tune to my puma at shepton mallet LR show and it's bl**dy fantastic, limiter is removed
![]() ![]() also had a V V Turbo for the TD5 from him ![]() ![]() ![]() |
urbanriot Member Since: 10 Jun 2010 Location: uk Posts: 19 ![]() ![]() |
Now then I need to confirm - are you related to Pete, have you ever been related to Pete, would you like to be related or have relations with Pete ? Apparently we need to confirm these details before we can big anyone up - and for gods sake do NOT mention the war. "I only said Jehova" |
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
snr69 Member Since: 30 Jun 2010 Location: UK Posts: 1 ![]() ![]() ![]() |
I'll give it a couple of days before I put my order in !
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 ![]() ![]() |
So is anyone going to tell me what a BAS retuned PUMA puts out. I assume a standard one is approx. 125PS and 277lb/ft.
Cheers Harvey |
Harvey,
I personally can't tell you what a BAS retuned Puma puts out but can post a link to some publicised figures for another tune for perusal: Ear tiz: http://www.james-french.co.uk/power-upgrades.asp If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
