Home > Puma (Tdci) > Puma Pedal Locks
Page 3 of 3 <123
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Dave-H wrote:
This is the Shire version i have .. Was �96 posted.
Covers the whole pedal area Wink
Hi Dave, what's it like for ease of fitment etc as some makes are apparently a b***er to fit. Cogito ergo sum
Post #241254 5th Jun 2013 4:53pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Dead easy Paul. first time was a bit fiddly [only seconds though] but once 'sussed' its straight on and off in a moment.
The lock is a C shape, just drop plate on pedal area with C shape between clutch and brake pedal, then slide it slightly right over the brake pedal and lock ... simples Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #241295 5th Jun 2013 8:35pm
Paul55
Thanks Dave, Thumbs Up Cogito ergo sum
Post #241299 5th Jun 2013 8:47pm
PAULUS
England 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi
Considering getting a pedal lock, do you have a picture of the rear of the shire version, looked at ard case but like people said you can still cut pedals & drive on stalks, ordered a X defend steering barrel lock as well, looks good quality but not had chance to fit it as yet.
Post #241437 6th Jun 2013 1:52pm
Dave-H
Here you go Very Happy
Post #241507 6th Jun 2013 7:46pm
BigWheels
Better but no sides. Looks more of a deterrent maybe.
Perhaps hardened steel or tungsten pedal stalks are needed (for all vehicles). Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #241524 6th Jun 2013 8:28pm
I'm waiting for x-eng to release their variant
the pedal lock jobbie is ok, but like other posts state you would not want that flying around your truck in an accident, even if you have tried to secure it.
Post #241526 6th Jun 2013 8:30pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I contacted X-Eng and they told me there were not going to produce a gear lever lock for the Puma, as apparently you can just pull the gear lever from the top of the box?
Makes a change from them snapping off like they do in 'series' motors I suppose. Euro-Leafing to infinity and beyond.....
Post #242615 10th Jun 2013 9:41pm
BigWheels
Strange (or maybe not) the delay in Puma pedal lockers. I saw from their web site that they are OOS of land anchors too.
Perhaps they are having issues with suppl/y/iers or raw materials. Confused Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #242631 10th Jun 2013 10:08pm
WarPig
Those with X-eng pedal locks, do you have to do away with the rubber floor mat?
Post #242636 10th Jun 2013 10:15pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
yes.
And no...
You could cut it to size, or replace it with something (I am thinking of a thin piece of rubber chequerplate on the inside).
I have, however, seen someone glue the original mat to the lock. A bit Heath Robinson, but seemed to work.
http://forums.lr4x4.com/index.php?showtopic=83569
Post #242751 11th Jun 2013 1:24pm
WarPig
Thanks. I guess this would mean everytime you lift the plate, any muck would get tipped behind the pedals?
I have the Adrennalin lock on my 300tdi and I fit it everytime I park up. When driving it lives between the two front seats. It is a bit of a pain, as It means I cant have my cubby tray there. I have considered the X-eng pedal lock but wouldnt want to loose my rubber floor mat.
Post #242840 11th Jun 2013 8:02pm
LRSoffroad
we have the ARDCASE the lads have also found out there has been to positions for the pedals on a 2012 on-wards only slight but enough for them not to fit also in true landrover fasion they fitted both from 2012 onwards nomater what the chassis number is Mr. Green
Post #242879 11th Jun 2013 10:19pm
Page 3 of 3 <123
