![]() | Home > Puma (Tdci) > Puma Pedal Locks |
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
Dead easy Paul. first time was a bit fiddly [only seconds though] but once 'sussed' its straight on and off in a moment.
The lock is a C shape, just drop plate on pedal area with C shape between clutch and brake pedal, then slide it slightly right over the brake pedal and lock ... simples |
| Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514
Thanks Dave,
| PAULUS Member Since: 25 Apr 2011 Location: WORCESTERSHIRE Posts: 12
Hi
Considering getting a pedal lock, do you have a picture of the rear of the shire version, looked at ard case but like people said you can still cut pedals & drive on stalks, ordered a X defend steering barrel lock as well, looks good quality but not had chance to fit it as yet. |
Here you go
Click image to enlarge Guns and Landrovers .... anything else is irrelevant. |
| BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405
Better but no sides. Looks more of a deterrent maybe.
Perhaps hardened steel or tungsten pedal stalks are needed (for all vehicles). Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender Last edited by BigWheels on 6th Jun 2013 8:30pm. Edited 1 time in total |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I'm waiting for x-eng to release their variant
the pedal lock jobbie is ok, but like other posts state you would not want that flying around your truck in an accident, even if you have tried to secure it. |
| strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1404
I contacted X-Eng and they told me there were not going to produce a gear lever lock for the Puma, as apparently you can just pull the gear lever from the top of the box?
Makes a change from them snapping off like they do in 'series' motors I suppose. Euro-Leafing to infinity and beyond..... |
Strange (or maybe not) the delay in Puma pedal lockers. I saw from their web site that they are OOS of land anchors too.
Perhaps they are having issues with suppl/y/iers or raw materials. |
| WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748
Those with X-eng pedal locks, do you have to do away with the rubber floor mat?
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
yes.
And no... You could cut it to size, or replace it with something (I am thinking of a thin piece of rubber chequerplate on the inside). I have, however, seen someone glue the original mat to the lock. A bit Heath Robinson, but seemed to work. http://forums.lr4x4.com/index.php?showtopic=83569 |
Thanks. I guess this would mean everytime you lift the plate, any muck would get tipped behind the pedals?
I have the Adrennalin lock on my 300tdi and I fit it everytime I park up. When driving it lives between the two front seats. It is a bit of a pain, as It means I cant have my cubby tray there. I have considered the X-eng pedal lock but wouldnt want to loose my rubber floor mat. |
| LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189
we have the ARDCASE the lads have also found out there has been to positions for the pedals on a 2012 on-wards only slight but enough for them not to fit also in true landrover fasion they fitted both from 2012 onwards nomater what the chassis number is
