![]() | Home > Puma (Tdci) > Service bulletin Q068v2 |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Great Pete and Great BAS Remap!!!!!!
IID Pro MV License |
| parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366
Phew, had me worried for a second.
Thank's for the reply pete. 130 crew cab 98 V8 Disco |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
No problem parktag..
For info for all. There is a limit for the IDS/SDD tool LandRover use as said, so i feel personally if your car drives good/ok without the new updates read about on the forum id personally not ask the dealer to do them. Some times the forum is like follow my leader with things like this, one member gets it done as the rest of the members think they are missing out lol so they ask the dealer about it. I always think like this, if LandRover have EG 15 times to reprogram your ecu before its full that is like a cat with 15 lifes. If you use those lifes up just because you want to follow my leader then when you most need them they are gone and you are then without a car untill landrover get you a new ecu. IF they are available because all the following sheep are now in the same boat as you !! Basicly id not ever ask for a update i know about from the forum UNLESS my car had problems or it was demanded i have it done by landrover them selfs. I dont know why LandRover program the ecu like they do adding records because there is really no need unless they have other reasons. Or may be they want to sell lots of ecus when pumas are 7 or 8 years old and out of warranty ! Ive proved my tool does not leave a trace by removing the 144pin PQFP processor from the ecu pcb before a flash and again after ive programed it many times, this lets me compare the data differences and there as i wanted was none
Pete |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
I didn't have the foresight to have one of BAS's upgrades, I wasn't a member of this site at the time and knew no difference! Things may have been different! Nevertheless as mentioned before I have an Autologic Remap that I am happy with and the difference to standard was amazinig! My engine runs and performs faultlessly! I have not had the previous two Land Rover upgrades due to the overwriting of my remap! I would undoubtedly if having a standard set up would have joined the stampede to get the upgrade for three main reasons; It's free, it may make my Defender perform like a Ferrari, I don't know any better!
Pete as a 'man in the know' are you implying that it is better not to have it done? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Hi
Its just my opinion, but as said if my car was running good and i was not demanded by landrover that i must have a update i would not have any at all. Why play with a perfeclty good car with no problems id be asking my self. Just as your car proved really, you have a remap on and have missed 2 updates and it still runs good ! Why change. Pete Last edited by bell-auto-services on 13th Jan 2010 9:28pm. Edited 1 time in total |
Pete,
Good points and well opinionated! I'm totally with you on this one! this could just be my suspicious nature but what better way of creating revenue than utilising all available programmable slots on a piece of very expensive equipment whilst under warranty and then owners being expected to pay for a replacement due to this fact at a later date! Just a supposition of course! Good revenue generator though! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154
After my truck threw a wobbler on Monday night and put the engine light on and P1169 fault code I booked it in for its 1st visit back to a dealer since I took delivery in October.
The Q068v5 patch seems to have sorted it out but I will need to drive it from properly cold a few times to be totally sure that I can't replicate the loss of power when accelerating. Initial impressions are that it seems to pull more smoothly through the gears but as I've only done 5 miles I'll reserve judgement for now. Chunk |
| mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286
Just for those that hadn't spotted my previous post:
http://www.defender2.net/forum/topic2455.html It's been waiting at the dealers for 3 days now while I wait for them to fit a new EGR valve that they think will fix the problem. Before the software update my Landie was fine (48k miles) and now it judders the transmission severely when coming off the throttle (any gear). I hope they prove me wrong with the EGR but it ran fine before the update and I can only assume the EGR was faulty then? If that doens't fix it I'll ask them what version of Q068 has been installed. Fingers crossed |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
ask them to re install QO68v2 2.4 90 XS
| cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336
Like K9F and Pete I took the view that if it's working then leave well alone - I have an Autologic remap and when it went into the dealer recently for a service I told them not to upgrade the ecu software - caused a few raisEd eyebrows but they were fine with it!
EGR on back order = hire car for even longer (what a pain in
| Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87
Had the 2-year service on my Apr/May 2008 90 XS SW yesterday and this Q068 Recall was applied - the authorised repairer didn't provide much info on what the issue was, and it was news to me as I'd not received any letter from anyone. Fortunately I came here and downloaded the full LR documentation and am now fully informed. I'll probably get a QA call from Land Rover sometime in the future asking my opinions on the service, and I will comment that they should issue the customer with a single page summary of what the Recall was about and what work has been done so you can add it into your own service history records. My gripe each service is also that I have to ask for a photocopy of the Maintenance Check Sheet for my records, which should be given by default.
I've never seen this Q068 effect on my truck fortunately. Trevor Wright '08 90 TDCi/TD4 XS SW |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
I`m kind of lost now
| NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972
Christ knows, but we had the most recent one applied about 3 weeks ago and the 'fender is MUCH quieter now and pulls more predictably
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
| All times are GMT |
