![]() | Home > Puma (Tdci) > Service bulletin Q068v2 |
| totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
I just had my software upgrade and its really improves the power and less roughness on the engine. thanks guys!
| Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514
Had mine done this morning, a lot smoother and quieter
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
you've been coasting down the hill again have'nt ya 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
| CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558
My consumption has now dropped to 11,3l/100
| jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172
I do 10 without the AC. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
| Ollram Member Since: 04 Jun 2007 Location: Athens, Greece Posts: 13
i will probably join your "club" owing a defender 110 SVX. However, teh serial no showed that the specific vehicle i'll buy, hass an open field service action, the Q068....
i guess that the previous owner has does all required with LR...but as a novice myself, how serious could be this fault??? cheers guys |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Hi Ollram it's not a fault it's just a new patch....no need to worry.. you're dealer should now if its been done or not give them a bell and they will let you know mate NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
QO68v5 is now out 2.4 90 XS
| mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286
Can you post a copy? |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
If you have a copy of previous version THE TEXT CONTENT IS THE SAME!!!!
change the pacth files that dealer use..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Would these updates not affect the number of re-writes on the chip which has only 15 re-programmes before the whole ECU has to be replaced?
Just a thought. |
Right you wrote Cape.... the 15 times limit is ONLY A SAFETY/MARKETING (eg BMW limit is "only" 12...) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Post for BAS Pete.....
Pete, the reprogramming limit is valid for BAS remap too???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
Hi, No this does not apply to the BAS remap interface you can program it as many times as you wish with my interface. We think like landrover some times, but others times think better Pete |
| All times are GMT |
