Home > Technical > HEAD LIGHT FLASH FAULT PUMA |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
Probably not what you'd like to hear but I would imagine the stalk has developed a fault. (especially if the fuses are all okay) Is it under warranty? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
8th Jan 2013 5:04pm |
ross0602 Member Since: 14 Jul 2012 Location: BD236JB Posts: 19 |
thanks for the reply. it had a new one on 6 weeks ago. 110 xs ute. 2.2
8th Jan 2013 5:07pm |
Ah, it's probably not that then. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
8th Jan 2013 5:09pm |
will have a look at the weekend 110 xs ute. 2.2
8th Jan 2013 5:30pm |
If you have a look behind there with a multimeter and do a bit of testing I'm sure you'll find the problem out. With no fuses blew it might perhaps be an earthing issue instead.
Good luck. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
8th Jan 2013 5:33pm |
I will have a look. It will be a wire fault. as it is a landy 110 xs ute. 2.2
8th Jan 2013 5:40pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
If it's just the flash that's not working and the constant dipped & main beam are ok my first check would be the brass contacts for the flash switching on the stalk. Steve.
8th Jan 2013 6:13pm |
