![]() | Home > Technical > HEAD LIGHT FLASH FAULT PUMA |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20889 ![]() ![]() |
Probably not what you'd like to hear but I would imagine the stalk has developed a fault. (especially if the fuses are all okay) Is it under warranty? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
ross0602 Member Since: 14 Jul 2012 Location: BD236JB Posts: 19 ![]() ![]() ![]() |
thanks for the reply. it had a new one on 6 weeks ago. 110 xs ute. 2.2
Ah, it's probably not that then.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
will have a look at the weekend 110 xs ute. 2.2
If you have a look behind there with a multimeter and do a bit of testing I'm sure you'll find the problem out. With no fuses blew it might perhaps be an earthing issue instead.
Good luck. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I will have a look. It will be a wire fault. as it is a landy
If it's just the flash that's not working and the constant dipped & main beam are ok my first check would be the brass contacts for the flash switching on the stalk. Steve.
