![]() | Home > Technical > HEAD LIGHT FLASH FAULT PUMA |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20992 ![]() ![]() |
Probably not what you'd like to hear but I would imagine the stalk has developed a fault. (especially if the fuses are all okay) Is it under warranty? ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
ross0602 Member Since: 14 Jul 2012 Location: BD236JB Posts: 19 ![]() ![]() ![]() |
thanks for the reply. it had a new one on 6 weeks ago. 110 xs ute. 2.2
Ah, it's probably not that then.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
will have a look at the weekend 110 xs ute. 2.2
If you have a look behind there with a multimeter and do a bit of testing I'm sure you'll find the problem out. With no fuses blew it might perhaps be an earthing issue instead.
Good luck. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I will have a look. It will be a wire fault. as it is a landy
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
If it's just the flash that's not working and the constant dipped & main beam are ok my first check would be the brass contacts for the flash switching on the stalk. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
