Home > Technical > HEAD LIGHT FLASH FAULT PUMA
ross0602
England 2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
Good afternoon,
My 110 xs puma has devloped a fault. The head light switch when you pull back on it to flash wont work. Main beam still works. I have checked all the fuses and none are blown. Tres confused! Rolling with laughter
Any help would be good. Thanks 110 xs ute. 2.2
Post #199959 8th Jan 2013 4:58pm
Probably not what you'd like to hear but I would imagine the stalk has developed a fault. (especially if the fuses are all okay) Is it under warranty? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #199962 8th Jan 2013 5:04pm
ross0602
thanks for the reply. it had a new one on 6 weeks ago. 110 xs ute. 2.2
Post #199964 8th Jan 2013 5:07pm
Ah, it's probably not that then. Confused ____\We|Will|Win/___
Post #199967 8th Jan 2013 5:09pm
ross0602
will have a look at the weekend 110 xs ute. 2.2
Post #199973 8th Jan 2013 5:30pm
If you have a look behind there with a multimeter and do a bit of testing I'm sure you'll find the problem out. With no fuses blew it might perhaps be an earthing issue instead.
Good luck. Thumbs Up ____\We|Will|Win/___
Post #199976 8th Jan 2013 5:33pm
ross0602
I will have a look. It will be a wire fault. as it is a landy Laughing 110 xs ute. 2.2
Post #199980 8th Jan 2013 5:40pm
Happyoldgit
If it's just the flash that's not working and the constant dipped & main beam are ok my first check would be the brass contacts for the flash switching on the stalk. Steve.
http://forums.lr4x4.com
Post #199995 8th Jan 2013 6:13pm
