Home > Puma (Tdci) > Service bulletin Q068v2
Page 4 of 8 <12345678>
dgardel
Italy
mse wrote:
Got mine back today and i have to say it seems smoother and less noisy - i can now hear more transmission noise (good or bad)
We will see how it runs.
probably LR reduced the EGR range......
I hope to do this SW upgrade asap... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #16853 18th Oct 2009 7:26pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Hi everybody!
Sunday while I was on mway, driving at 120 km/h, my 110 made a lot of smoke from the tailpipe, but only over 100 km/h, indifferently I was uphill or downhill.
Yesterday, while I was driving at 100 km/h, suddenly the engine lost power, as the turbine was off, slowing down in every gear.
I stoped immediately,I switched off and turned on the engine and everything was again ok, even if the engine did not run as regular as before.
The MIL light did not turned on.... Matteo
Defender 110 Td4 SE MY 09
Post #16919 20th Oct 2009 9:01am
Bomber82
Today again, while I was driving at 60 miles, the engine lost power, I downshifted in fifth and the engine could run not more then 2000 rpm.
Only turning off the engine the problem disappear...
What could be??? Big Cry Matteo
Post #17042 22nd Oct 2009 3:41pm
mse
has the patch been applied - ive only done about 70 miles in mine but at upto 70mph Mike
Post #17050 22nd Oct 2009 4:58pm
Bomber82
What is the patch you are talking about? Matteo
Post #17052 22nd Oct 2009 5:09pm
mse
This service bulletin is a patch to the ECU Mike
Post #17053 22nd Oct 2009 5:21pm
Bomber82
OK!
and do you find some differences with the older? Matteo
Post #17064 22nd Oct 2009 8:24pm
mse
Bomber82 wrote:
OK!
Hell Yes - thats the purpose of the posts here Thumbs Up Mike
Post #17065 22nd Oct 2009 8:45pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I got the software update last week when mine went in for a new clutch part - I couldn't notice any difference apart from a slight lag in power take-up when changing up to forth... this will probably become unnoticeable soon as my driving style will probably adapt to it.
I did notice the fuel gauge didn't move much over 100 miles though, but I was crawling on minor roads coming home from Somerset after the M5 was closed due to that accident with the power cables... it does seem to be more efficient at slow speeds! I'll know for sure if there is really any improvement when I next fill up.
Post #17088 23rd Oct 2009 10:28am
Willie
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Had mine done on Friday and it is definitely smoother and quieter. Also seems have more power at lower revs.
Willie Defender Virgin
Post #17205 26th Oct 2009 12:05am
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
It has finally reached Portugal. Booked in for the 16th.
Courtesy Range Rover booked also. Cool
Post #17897 5th Nov 2009 3:29pm
3WHouse
Russia 2007 Defender 110 Puma 2.4 SW Java Black
It is normal.
Q068v2 - full Censored ..))) Def`s 90 & 110 Monochrome.
You can go fast i can go anywhere.))
http://www.offroadpower.ru/
Post #17905 5th Nov 2009 5:20pm
dgardel
Italy
me too
patch installed but the car run like before the patch.....
Bhà!!!
now dealer want to install the Q68V4 (yes Q68 is arrived at 4th revision Shocked ) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #17913 5th Nov 2009 8:47pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I think i had this done last week because when i got the truck back it sounded a little more rougher in the sense of the engine was louder and definitely quicker the dealer said it had the new patch i just thought they had reprogrammed the old one Q068v2 again because it was in for a new gearbox, i'm back in on Thursday i'll ask NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #17915 5th Nov 2009 9:09pm
totoD110
guys! do I need to update mine even if I dont have MIL on my dash light? TIA
Post #17971 7th Nov 2009 12:51pm
