![]() | Home > Puma (Tdci) > Service bulletin Q068v2 |
probably LR reduced the EGR range...... I hope to do this SW upgrade asap... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
Hi everybody!
Sunday while I was on mway, driving at 120 km/h, my 110 made a lot of smoke from the tailpipe, but only over 100 km/h, indifferently I was uphill or downhill. Yesterday, while I was driving at 100 km/h, suddenly the engine lost power, as the turbine was off, slowing down in every gear. I stoped immediately,I switched off and turned on the engine and everything was again ok, even if the engine did not run as regular as before. The MIL light did not turned on.... Matteo Defender 110 Td4 SE MY 09 |
Today again, while I was driving at 60 miles, the engine lost power, I downshifted in fifth and the engine could run not more then 2000 rpm.
Only turning off the engine the problem disappear... What could be??? ![]() Defender 110 Td4 SE MY 09 |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5102 ![]() ![]() ![]() |
has the patch been applied - ive only done about 70 miles in mine but at upto 70mph Mike
What is the patch you are talking about? Matteo
This service bulletin is a patch to the ECU Mike
OK!
and do you find some differences with the older? Matteo Defender 110 Td4 SE MY 09 |
Hell Yes - thats the purpose of the posts here ![]() |
Willie Member Since: 08 Oct 2009 Location: Stockton Posts: 48 ![]() ![]() ![]() |
Had mine done on Friday and it is definitely smoother and quieter. Also seems have more power at lower revs.
Willie Defender Virgin |
jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172 ![]() ![]() ![]() |
It has finally reached Portugal. Booked in for the 16th.
Courtesy Range Rover booked also. ![]() |
3WHouse Member Since: 24 Jan 2008 Location: Msk Posts: 70 ![]() ![]() ![]() |
It is normal. Q068v2 - full ![]() You can go fast i can go anywhere.)) http://www.offroadpower.ru/ |
me too
patch installed but the car run like before the patch..... Bhà!!! now dealer want to install the Q68V4 (yes Q68 is arrived at 4th revision ![]() ![]() IID Pro MV License |
I think i had this done last week because when i got the truck back it sounded a little more rougher in the sense of the engine was louder and definitely quicker the dealer said it had the new patch i just thought they had reprogrammed the old one Q068v2 again because it was in for a new gearbox, i'm back in on Thursday i'll ask NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
guys! do I need to update mine even if I dont have MIL on my dash light? TIA
