![]() | Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
With A REAL PLUG & PLAY solution....
buy this click for ebay Volskwagen code: 357 955 531 or 3B0 955 531 Bosch code: 0 986 335 058 Beru code: 0 900 301 082 To program is easy: Push down on the w-w lever, have it wipe once, bring it up and wait until you need to wipe again, then push it down. It'll use the same wait interval! Very clever, but not obvious. more info and more spare parts code here Selec wiki Happy to improve our Puma Click image to enlarge
Click image to enlarge Last edited by dgardel on 15th Sep 2009 11:40pm. Edited 3 times in total |
Down being intermittent yes but with fixed time interval. with this relay you can change the intermittent time interval duration |
Its works in this way:
1. light rain put DOWN the WW lever and then up (off) 2. wait XX seconds 3. put DOWN again the WW lever from now the WW start automatically EVERY XX seconds. When you switch off again the WW the system resets itself at 6 seconds. and again 1. After a short spray of the screen there is only 1 wipe in stead of 4. 2. After a longer spray of the screen there is only 3 wipes in stead of 4. Last edited by dgardel on 15th Sep 2009 11:55pm. Edited 1 time in total |
p.s. payed 9.99 USD on ebay (plus 7 USD of postage cost)
| dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
Good find nice one
110 HCPU Tipper |
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505
Great mod i shall get one ready for the rainy season
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
Will this work on a TD5 too? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| Anvil Member Since: 16 Jan 2009 Location: Milan Posts: 21
I was wondering this morning about adjustable delay. I'll definitely check it out
Yes!!! |
I don't know on Tdi but check the installed intermittence, if it has the same P/N of Td5 and Puma you can do it. it's a red relay case box on the fusible bay under the steering wheel. This late evening I'll check the P/N of my original intermittence (I'm in office now) and I'll write here. Last edited by dgardel on 16th Sep 2009 12:52pm. Edited 2 times in total |
Yes!!! |
Thanks,
I will get one too then. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
