![]() | Home > Technical > best shockers |
devon have those on special this month ![]() |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Mk did you have those made ? Are they standard length or plus 5 ?
Regards steve. 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Yes, they are kind of bespoke regarding the valving and mount ends. Fox have all kind of bits to accomodate your needs and it does not cost more actually. These are 11" travel. Fox do not sell directly their stuff, but they forward you to a retailer. Customer service is not the best but I finally found a shop in the states where they know their bussines.
Of course there are bigger and ultra fancy ones but they cost a lot of $. Anyhow cheaper than king shocks. Puma 110" SW ............................................................. Earth first. Other planets later |
Cool will they fit on standard mounts though 2015 2.2 tdci hardtop xs
Not in the rear. I have all corners with stem-stem mounts. Puma 110" SW
Yer but do you only need a set of Devon 4x4 pin mounts though ?
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
I got mine long time ago from G Lewis. I would say it is a better option because sometimes the OE mount or shock loop brakes damaging the fuel filter, lines, etc. And that is the end of the trip. Puma 110" SW
Yer same same then cool you will have to put some pics up of them mounted 2015 2.2 tdci hardtop xs
