![]() | Home > Technical > best shockers |
If you go for TF116/117 they are cheaper here (price excludes VAT) but they work out about £55 a pair.
http://shop.defenderbits.co.uk/defender-te...-648-p.asp Andrew, the owner, is very helpful, maybe drop him an email or call him and ask for his opinion. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 ![]() ![]() ![]() |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Yep, thats the kiddies i use
![]() Good price too ... £30 each delivered ![]() |
cheers folks
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Bilstien
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
I'm getting a set of Bilsteins from a mate who is going for a 3" lift. Can't wait to feel the difference! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
what model of Bilstein's do you recomend ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Hi, i have front H/D 625670020
Rear H/D 625530030 They have totally transformed the ride ![]() |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 630 ![]() ![]() ![]() |
So if you were going to upgrade the suspension would you have to do everything at the same time; springs, shocks and bushes or can you do them individually. Also if you did them individually where would you start?
No but it may be easier for some of the components ![]() Shocks can be done on their own by removing bottom bolt, top turret (or just top nut for the back) and then the turret + shock (front) can be removed via the wing inspection plate, rears are just taken off. To change the front springs it is easiest to remove the shock as well so you may as well do both at the same time. Rear springs can be done on their own. Bushes - depends on which ones you are going to change. new shocks should have new bushes with them. I am in the process of doing rear shocks and front shocks + turrets + springs. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Thanks Bob, that is really useful info as I have never done this before. My quest is to improve the ride a little and was thinking of replacing the shocks first to see what difference that makes. Also I need to replace some of the bushes as they were an advisory on the last MOT. So I guess I can leave the springs till later when my bank balance has recovered!! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8342 ![]() ![]() ![]() |
i would always start with bushes first if the ride was bad and the vehicle had a few miles on it.
with good bushes if its not as you wish then you can start to look at other components. Superpro get my vote for bushes. As Bob says front dampers and springs at the same time makes sense to reduce man hours. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
What characteristics of standard Puma shocks might be improved with different ones - mainly thinking of road use? Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
Can't find them under that ref. ... What model are they ? B6 ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
