Home > Technical > best shockers
Page 2 of 4 <1234>
bob neville
If you go for TF116/117 they are cheaper here (price excludes VAT) but they work out about £55 a pair.
http://shop.defenderbits.co.uk/defender-te...-648-p.asp
Andrew, the owner, is very helpful, maybe drop him an email or call him and ask for his opinion.
2013 Defender 90 CSW - sold
Post #120205 31st Jan 2012 9:34pm
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
Bob
Thumbs Up Very Happy
Post #120219 31st Jan 2012 9:52pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Yep, thats the kiddies i use Smile
Good price too ... £30 each delivered Cool Guns and Landrovers .... anything else is irrelevant.
Post #120221 31st Jan 2012 9:57pm
jst
for what you are using the truck for i wouldnt go all out.
std woodhead (i think they are) have obviously done a good job upto now so shouldn't be discarded.
Failing that on a budget TF work well in my opinion, i run 3 vehicles with them on the rear and no probs to date.
if you have more to spend OME would be the way fwd, i run these as fronts on two vehicles and they are very good. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #120224 31st Jan 2012 10:13pm
Harryb450
cheers folks Thumbs Up
Post #120230 31st Jan 2012 10:21pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Bilstien Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #120232 31st Jan 2012 10:27pm
Naks
fekete wrote:
Bilstien Thumbs Up
I'm getting a set of Bilsteins from a mate who is going for a 3" lift. Can't wait to feel the difference! --
Post #120274 1st Feb 2012 9:26am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
fekete wrote:
Bilstien Thumbs Up
what model of Bilstein's do you recomend ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #120303 1st Feb 2012 12:37pm
fekete
Hi, i have front H/D 625670020
Rear H/D 625530030
They have totally transformed the ride Mr. Green NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #120308 1st Feb 2012 1:18pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
So if you were going to upgrade the suspension would you have to do everything at the same time; springs, shocks and bushes or can you do them individually. Also if you did them individually where would you start?
Post #120315 1st Feb 2012 1:53pm
bob neville
No but it may be easier for some of the components Thumbs Up
Shocks can be done on their own by removing bottom bolt, top turret (or just top nut for the back) and then the turret + shock (front) can be removed via the wing inspection plate, rears are just taken off.
To change the front springs it is easiest to remove the shock as well so you may as well do both at the same time.
Rear springs can be done on their own.
Bushes - depends on which ones you are going to change. new shocks should have new bushes with them.
I am in the process of doing rear shocks and front shocks + turrets + springs.
Post #120323 1st Feb 2012 2:34pm
dnorrishill
Thanks Bob, that is really useful info as I have never done this before.
My quest is to improve the ride a little and was thinking of replacing the shocks first to see what difference that makes. Also I need to replace some of the bushes as they were an advisory on the last MOT. So I guess I can leave the springs till later when my bank balance has recovered!!
Post #120329 1st Feb 2012 3:06pm
jst
i would always start with bushes first if the ride was bad and the vehicle had a few miles on it.
with good bushes if its not as you wish then you can start to look at other components.
Superpro get my vote for bushes.
As Bob says front dampers and springs at the same time makes sense to reduce man hours. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #120330 1st Feb 2012 3:08pm
ZeDefender
What characteristics of standard Puma shocks might be improved with different ones - mainly thinking of road use? Tell someone you love them today because life is short.
Post #120332 1st Feb 2012 3:11pm
lrmaniac
Rear H/D 625530030
Can't find them under that ref. ... What model are they ? B6 ? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #120339 1st Feb 2012 3:26pm
Page 2 of 4 <1234>
