Home > Puma (Tdci) > 2009 - 90 pulling to left ? |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 |
Whip the centre cap off, oh get the wheels facing forwards first, then cap off, undo big nut in the middle, pull steering wheel off, and place true on the splines do but up, replace cap and bobs your granny 90 Puma HT
24th Feb 2012 9:33pm |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 |
Genius Dare I ask how the centre cap comes off? |
24th Feb 2012 9:38pm |
Put some Vaseline on a screw driver, and ease in from top or btm, the edges have longer bits on! Then leaver out gently!! 90 Puma HT
24th Feb 2012 9:41pm |
Regarding the pulling to the left..
Check you tyre pressures Do you get any steering wobble at specific speeds? - check your steering damper Otherwise check with CR - he has the same problem unless he's fixed it |
25th Feb 2012 7:46am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
what he said. if they're all find check your track rod ends and rod itself. if thats all ok get it laser tracked. if that doesn't solve it check the steering box.
25th Feb 2012 8:00am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
I thought mine was drifting to the left quite a bit, until we left the UK on a trip to France. On straight roads it was perfectly fine.
Back in the UK, again started drifting to the left. In my case it was a subtle drift, due to the surface camber (sp?). |
25th Feb 2012 9:23am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7716 |
sticking pistons on RHS? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
25th Feb 2012 12:30pm |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
swop wheels over left/right.
Pom |
25th Feb 2012 3:29pm |
