![]() | Home > Puma (Tdci) > 2009 - 90 pulling to left ? |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Whip the centre cap off, oh get the wheels facing forwards first, then cap off, undo big nut in the middle, pull steering wheel off, and place true on the splines do but up, replace cap and bobs your granny 90 Puma HT
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 ![]() ![]() ![]() |
Genius ![]() Dare I ask how the centre cap comes off? |
Put some Vaseline on a screw driver, and ease in from top or btm, the edges have longer bits on! Then leaver out gently!!
Regarding the pulling to the left..
Check you tyre pressures Do you get any steering wobble at specific speeds? - check your steering damper Otherwise check with CR - he has the same problem unless he's fixed it |
what he said. if they're all find check your track rod ends and rod itself. if thats all ok get it laser tracked. if that doesn't solve it check the steering box.
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
I thought mine was drifting to the left quite a bit, until we left the UK on a trip to France. On straight roads it was perfectly fine.
Back in the UK, again started drifting to the left. In my case it was a subtle drift, due to the surface camber (sp?). |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8291 ![]() ![]() ![]() |
sticking pistons on RHS? Cheers
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
swop wheels over left/right.
Pom |
