Home > Puma (Tdci) > 2009 - 90 pulling to left ?
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Just picked up my 2009 Defender 90 and love it other than the steering wheel isnt true. In a straight line it's way offline, also the car does seem to pull a bit to the left, but that could be the lousy roads.
Any ideas???
Post #126490 24th Feb 2012 9:27pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Whip the centre cap off, oh get the wheels facing forwards first, then cap off, undo big nut in the middle, pull steering wheel off, and place true on the splines do but up, replace cap and bobs your granny 90 Puma HT
Post #126492 24th Feb 2012 9:33pm
mlightfoot
Genius Very Happy
Dare I ask how the centre cap comes off?
Post #126498 24th Feb 2012 9:38pm
Jammer600
Put some Vaseline on a screw driver, and ease in from top or btm, the edges have longer bits on! Then leaver out gently!! Razz 90 Puma HT
Post #126503 24th Feb 2012 9:41pm
Regarding the pulling to the left..
Check you tyre pressures
Do you get any steering wobble at specific speeds? - check your steering damper
Otherwise check with CR - he has the same problem unless he's fixed it
Post #126565 25th Feb 2012 7:46am
BigMike
what he said. if they're all find check your track rod ends and rod itself. if thats all ok get it laser tracked. if that doesn't solve it check the steering box.
Post #126568 25th Feb 2012 8:00am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I thought mine was drifting to the left quite a bit, until we left the UK on a trip to France. On straight roads it was perfectly fine.
Back in the UK, again started drifting to the left. In my case it was a subtle drift, due to the surface camber (sp?).
Post #126580 25th Feb 2012 9:23am
jst
sticking pistons on RHS? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #126615 25th Feb 2012 12:30pm
pom
swop wheels over left/right.
Pom
Post #126643 25th Feb 2012 3:29pm
