Home > Wheels & Tyres > Bf Goodrich question |
Bearcat Member Since: 09 Dec 2011 Location: Dublin Posts: 57 |
Are the mud rails easy to fit? Current...07 90 Puma commercial
Porsche 930 1988 (laid up) Previous Td5 90 & V8 90 |
13th Feb 2012 2:52pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
P o P to fit
13th Feb 2012 4:06pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19649 |
Mine
Click image to enlarge Quite dirty though Last edited by custom90 on 23rd Feb 2012 8:41pm. Edited 1 time in total |
13th Feb 2012 6:50pm |
well men, my man at needamerc who restore G wagens went to the dark side fitting the BFs, fitting hella 3000s and in the process of doing leds.....side lights and remaining led tomorrows work sheet. I think it looks a bit of all right......fitted a terrafirma damper so hopefully all done 2m.....remaining work will be chequer plating (black or silver?), light protector at the rear and a concealed locomotive horn...that can is kicked up the road until funds are in hand again.....i know a bit childish at 46 yrs old re the loco horn but it'll be a bit of fun in non public areas....(cough)....you only pass through here once says me.
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Current...07 90 Puma commercial Porsche 930 1988 (laid up) Previous Td5 90 & V8 90 |
23rd Feb 2012 8:36pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
Black cp on silver
Andy |
23rd Feb 2012 10:14pm |
rog.....black it is......totally smashed now post the bf's....might do the bonnet in black also Current...07 90 Puma commercial Porsche 930 1988 (laid up) Previous Td5 90 & V8 90 |
23rd Feb 2012 11:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16929 |
What do you have in mind for an air supply for the horn? I have a pair of horns off a BR mainline diesel loco in the shed and have always been tempted by the idea of fitting them. We have a lot of very elderly and discombobulated drivers in Dorset, and the evil demon in me wants to sneak up behind one when it is just driving onto one of Dorset's level crossings and let go with a two-tone blast of diesel horn to see what happens! Perhaps it would be best if I didn't try it. |
24th Feb 2012 10:40am |
A friend of mine has a loco horn on his Series I. He runs it off a small air tank, which he fills with an air line. I think he gets about 4-5 seconds out of it, but it only needs to be used sparingly for the desired result anyway Darren
24th Feb 2012 10:53am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
Looks good Bearcat
Whats the difference between 265 & 285? Can you put 285 on Dual Finish wheels suppose they are same size as Boosts? I'd like some one day, probably 265 as this seems to be a more common size but not sure why |
24th Feb 2012 2:33pm |
Er, 20mm ! Well, plus 20mm on width and plus 15mm on height.
Yes, as far as I know they are the same size. There are some people who will tell you that a Boost rim is too narrow for a 286 (and it is narrower than BFG recommends) but there are enough of us running them to suggest otherwise.
265s put less crap all over the side of the vehicle than 285s and the Boost rim is within the range recommended by BFG as suitable. 265s do not materially alter the turning circle, whereas 285s really need 30mm spacers or a +30mm offset wheel in order to maintain the turning circle. To some people the wider aspect of the 285 looks better than the 265, but to others vice versa (aesthetics are purely subjective). Performance-wise there is little to choose, the additional flotation of a 285 over a 265 is not sufficient to be significant. But 285s do look good! |
24th Feb 2012 2:48pm |
Thanks once again Wolfy
Time to save up for some 265's then |
24th Feb 2012 2:54pm |
Be aware some tyre fitters will not fit a 285 on a 7J rim
24th Feb 2012 3:00pm |
finished job, thanks to my mate eddie. I think she looks the biz ( i would).....this is the cleanest i ever seen it, it'll be on dirty country lanes soon earning its keep.
Click image to enlarge Click image to enlarge :D Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Current...07 90 Puma commercial Porsche 930 1988 (laid up) Previous Td5 90 & V8 90 |
24th Feb 2012 4:03pm |
Looks great, you were lucky with the tyres, you can't get them anymore.......confusing if they were such a good seller unless they are bringing in a new design Cooper must be doing well out of the cock up
24th Feb 2012 5:04pm |
