Home > Td5 > TD5 Engine
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TD5 Engine
Evening
So, still haven't resolved the alarm issue but now have bigger problems.
I will try and make this brief.
Landy was running fine until a week ago. I started to get vibration in the cab when hitting a certain RPM.
I thought it might have been a wheel bearing but no wobble in the wheel at all.
I then thought it was the front prop and maybe the UJs.
I took the prop off today and took it out for a drive. Yes, with diff lock on Smile
At first the engine seemed to run fine and acceleration was good. However when I hit 35mph the wobble was there, even worse now!
When trying to come up a hill there seemed to be a lack of power and it struggled!
Back home it would rev ok but as the revs reduced to idle there seemed to be a rattle, maybe.
So, bottom end or maybe a duff injector?
I have a nanocom, how do I use it to find out if a injector has gone.
If not, then that will be the end of the road as too expensive to replace the engine.
Help
Tank
Post #1077852 18th Oct 2025 7:38pm
revd
check the injector loom, cheap to just swap out if in doubt
Post #1077862 18th Oct 2025 9:24pm
landy andy
Have you checked your turbo wastegate is freely moving?
Post #1077877 19th Oct 2025 7:21am
TexasRover
You can click each injector with the nanocom, but I don't know if that would diagnose a failed injector. Also I would think you would see smoke unless it's not firing (misfire)
You say the vibrations were there at 30 mph, but think it's the engine. If it's the engine it would be a certain rpm or maybe certain load and rpm. Are you sure you have decisively excluded the drivetrain?
Post #1077879 19th Oct 2025 8:05am
Tank
Its defo not the turbo actuator, its a new turbo and know what that's like from previous problems. It move freely.
The Landy revs ok on the drive with no load.
Will have a look at the injector loom once the rain stops, if it ever does. Could that cause an issue if the engine was under load and cause a misfire.
Could the vibration be a misfire underlay. Acceleration is still great.
With the prop shaft removed I still get the vibration. There isn't must left at the front in respect of drive train. Could a duff half shaft be the problem? The diff has no load being put trough it without the prop shaft connected so wouldn't have thought it was the diff?
Very strange.
She is an old girl, 231,000 miles and 2004 plate Smile
Post #1077893 19th Oct 2025 2:59pm
jst
oil in loom as above, our 110 hicap had same symptons Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1077894 19th Oct 2025 3:01pm
Tank
Really! Oooh would be great if it was that!
So same power issues etc et
Post #1077896 19th Oct 2025 3:33pm
Tank
Ah well.
So it wasn't the loom. Shame. Easy job but there you go.
Took it out for another run and accelerates and drives fine on the flat but on hills it struggles.
Think the judder is coming from the clutch.
Will take it to the experts this week and see what they say.
Thanks for all the advice.
Tank
Post #1078038 21st Oct 2025 8:29pm
landy andy
Driven it with MAF disconnect?
Give it a try.
Post #1078039 21st Oct 2025 8:32pm
Tank
Evening
So, turns out to be the DMF ! Who knew.
The vibration has gotten worse and it became much easier to determine it was the flywheel giving up the ghost ! Oh well. Some work done that wasnt required Rolling with laughter
Turns out running 180 - 195bhp with a standard flywheel only lasts 7-8 years, which isnt bad. The LOF clutch plate is still ok but the DMF has left the chat Rolling with laughter
New LOF VNT EXTREMEspec kit with SMF and the rest of the bits ordered. Ordered on the Thursday and came today! Super fast service.
Wish it could get fitted as fast. Not booked in until the 13th of November to have it done, oh well.
Thanks again for all the advice. Really appreciated.
Post #1078244 24th Oct 2025 4:04pm
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
FYI, I have the Single mass flywheel in storage waiting to be installed, prob next summer too lazy. yes cost savings is my main reason i bought it but be prepared for the best vibration you will ever have.
As you now learned with a faulty dual flywheel the significance of its dampening capabilities for the motor. wait until you instALL the single flywheel. I dont care personally vibration, if I wanted calm i would have bought a prius but dont expect the same drive you had before.
And cracked flywheels is a td5 fault so not surprised, kind of common
Post #1078299 25th Oct 2025 7:03am
TexasRover
It's important to recognize that the clutch drive (friction) plate for a dual mass flywheel does not have the torsional springs, while the drive plate for a single mass flywheel does. You be getting a pretty rough ride if you were to just change the flywheel with a single mass. Who would not change the drive plate whilst in there, but you might be tempted to is you were going low budget
Post #1078302 25th Oct 2025 8:22am
