Home > Td5 > TD5 Engine
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TD5 Engine
Evening
So, still haven't resolved the alarm issue but now have bigger problems.
I will try and make this brief.
Landy was running fine until a week ago. I started to get vibration in the cab when hitting a certain RPM.
I thought it might have been a wheel bearing but no wobble in the wheel at all.
I then thought it was the front prop and maybe the UJs.
I took the prop off today and took it out for a drive. Yes, with diff lock on Smile
At first the engine seemed to run fine and acceleration was good. However when I hit 35mph the wobble was there, even worse now!
When trying to come up a hill there seemed to be a lack of power and it struggled!
Back home it would rev ok but as the revs reduced to idle there seemed to be a rattle, maybe.
So, bottom end or maybe a duff injector?
I have a nanocom, how do I use it to find out if a injector has gone.
If not, then that will be the end of the road as too expensive to replace the engine.
Help
Tank
Post #1077852 18th Oct 2025 7:38pm
revd
check the injector loom, cheap to just swap out if in doubt
Post #1077862 18th Oct 2025 9:24pm
