Home > Td5 > TD5 Engine
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TD5 Engine
Evening
So, still haven't resolved the alarm issue but now have bigger problems.
I will try and make this brief.
Landy was running fine until a week ago. I started to get vibration in the cab when hitting a certain RPM.
I thought it might have been a wheel bearing but no wobble in the wheel at all.
I then thought it was the front prop and maybe the UJs.
I took the prop off today and took it out for a drive. Yes, with diff lock on Smile
At first the engine seemed to run fine and acceleration was good. However when I hit 35mph the wobble was there, even worse now!
When trying to come up a hill there seemed to be a lack of power and it struggled!
Back home it would rev ok but as the revs reduced to idle there seemed to be a rattle, maybe.
So, bottom end or maybe a duff injector?
I have a nanocom, how do I use it to find out if a injector has gone.
If not, then that will be the end of the road as too expensive to replace the engine.
Help
Tank
Post #1077852 18th Oct 2025 7:38pm
revd
check the injector loom, cheap to just swap out if in doubt
Post #1077862 18th Oct 2025 9:24pm
landy andy
Have you checked your turbo wastegate is freely moving?
Post #1077877 19th Oct 2025 7:21am
TexasRover
You can click each injector with the nanocom, but I don't know if that would diagnose a failed injector. Also I would think you would see smoke unless it's not firing (misfire)
You say the vibrations were there at 30 mph, but think it's the engine. If it's the engine it would be a certain rpm or maybe certain load and rpm. Are you sure you have decisively excluded the drivetrain?
Post #1077879 19th Oct 2025 8:05am
