![]() | Home > Td5 > Interior lights. |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1693 ![]() ![]() |
1 door open should turn them all on .
the lights corrode on the terminals so drop them down and clean and refit and they should be fine |
mattsccm Member Since: 11 Jul 2022 Location: Glos Posts: 19 ![]() ![]() ![]() |
Cheers, that's planned for tomorrow. Rear is especially awkward. As in female.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 1000 ![]() ![]() ![]() |
Consider adding CREE LED light strips over the doors and replace the dome festoon bulbs with an LED sheet.
Good luck. ![]() Click image to enlarge ![]() Click image to enlarge 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Cheers. They don't need to be bright, just capable of switching on and off when they are supposed to. One flashes on when I go around a right hand bend. Suspect that the terminal inside the body is swing against the body. Wish there was no bloody delay though. Ah well, another Td5 thing I don't want.
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 863 ![]() ![]() ![]() |
It sounds like your door switches probably need cleaning. I'm pretty sure they are the same as on the 300TDi and the copper contacts are exposed to atmosphere are prone to gunking up and oxidising.
I had fairly good success in a small cheap ultrasonic cleaner. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
