Home > Td5 > Interior lights.
mattsccm
United Kingdom 2007 Defender 90 Puma 2.4 HT Epsom Green
Interior lights.
My 110 SW has the normal two interior lights which, as designed, are a touch temperamental. My last 110 wasn't new enough for door switches and I am not sure. Should all the door switches work both lights or do the front switches do the front lights and the rear switch its own light? My rear light needs some work as it has a mind of its own.
Post #1077845 18th Oct 2025 6:52pm
Mdm
1 door open should turn them all on .
the lights corrode on the terminals so drop them down and clean and refit and they should be fine
Post #1077848 18th Oct 2025 7:01pm
mattsccm
Cheers, that's planned for tomorrow. Rear is especially awkward. As in female. Laughing
Post #1077859 18th Oct 2025 8:51pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Consider adding CREE LED light strips over the doors and replace the dome festoon bulbs with an LED sheet.
Good luck.
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1077956 20th Oct 2025 6:51pm
mattsccm
Cheers. They don't need to be bright, just capable of switching on and off when they are supposed to. One flashes on when I go around a right hand bend. Suspect that the terminal inside the body is swing against the body. Wish there was no bloody delay though. Ah well, another Td5 thing I don't want.
Post #1077966 20th Oct 2025 9:14pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
It sounds like your door switches probably need cleaning. I'm pretty sure they are the same as on the 300TDi and the copper contacts are exposed to atmosphere are prone to gunking up and oxidising.
I had fairly good success in a small cheap ultrasonic cleaner. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1077975 20th Oct 2025 10:03pm
TexasRover
The interior light can be switched through the AS10 (not sure when they started to introduce that, maybe Td5?). It has a feature where if you leave the door open, rather than drain the battery overnight it switches the light off after a certain period. The system is reset once you close the door, but obviously it's based on the signals it gets from the door switches. Soooo if the switches are bad you can get some funky behavior. Best to regularly check those switches en just get a bunch and change them out.
Post #1078015 21st Oct 2025 1:39pm
