Home > Technical > Replacement Door Hinges
jst
Well my 2010 110 driver door bottom hinge has just about had it, so much play that door has dropped. not great but it is a LR.
for now i have replaced it with a std one. but it got me thinking
should i be looking to fit something better/serviceable. (had a 99 Td5 top hinge failed after 9 years so its not a new problem)
if replacing an upgrading should i look to add some security features too
anyway a little digging found these:
http://optimillraceproducts.com/product_in...ucts_id=33
rears ^^^
and front:
https://houseofurban.co.uk/shop/defender/b...-defender/
cheaper:
https://www.devon4x4.com/da1305-defender-s...inges.html
security wise.
https://goreproducts.com/products/defender...hinge-kits
not sure how much of a pain these would be to fit ^^^
also those bomb proof plates to consider for security.
what have others done?
PS - cant believe the cost £720 for a 110.... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #685121 8th Feb 2018 9:32pm
ericvv
Post #685127 8th Feb 2018 9:43pm
jst
thank you, i remember this thread, but couldnt find it! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #685135 8th Feb 2018 9:52pm
Retroanaconda
I’ve just this week ordered a pair of hinges for the drivers door of mine as the bottom hinge is now worn enough to affect closing. It seems the lifespan for a hinge in regular use is about 8 years or so as I think I fitted these in 2009/2010.
I went for genuine ones, all the others are either ugly or very expensive. Will hopefullly fit them this weekend.
A better solution in my opinion would be to modify genuine hinges to accept grease. There is a thread on this on the LR4x4 forum.
Post #685136 8th Feb 2018 9:52pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Cheaper route... open door, drill 1.5 or 2mm hole in centre of the hinge and pump in grease with a chainsaw grease gun. You can feel the drill touch the hingepin.
Post #685187 9th Feb 2018 6:24am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Another thread on the subject: http://www.defender2.net/forum/topic52994.html
Post #685261 9th Feb 2018 12:35pm
geobloke
Top idea! Thumbs Up
Post #685335 9th Feb 2018 6:52pm
Procta
I am looking at this too, I wouldn't mind the gore ones, but I am not sure how plug in play those would be. Anyone know who has them fitted? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #685375 9th Feb 2018 9:21pm
jst
I would also he interested to know if they use studs or bolts in gore ones , anyone on here have them? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #685395 9th Feb 2018 10:27pm
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
I need to replace the 2nd row lower hinge on the RH (drivers) side. Is it the same part as that on the front row lower? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1076865 4th Oct 2025 1:28pm
Mr.Jimbo
United Kingdom 2003 Defender 110 Td5 CSW Java Black
Yes, the only change to the hinges are if they’re drilled for the wing mirrors, otherwise the left hand (and vice versa right hand) upper and lower are geometrically the same.
That’s certainly the case for the later TD5 style 2003 TD5 110 CSW
Instagram: e12_hue
Post #1076892 5th Oct 2025 6:47am
Andyslandytd5
Great thanks 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1076897 5th Oct 2025 7:49am
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
Just an fyi, you are overpaying for door hinges if you didnt know. by about a few hundred bucks. You can buy 8 full sets for 8 vehicles for the price of 1 set proposed via link. or buy 8 sets and have them last 80 years hahaha.
Just get an original one for total cost of 60 pounds and spray paint them. Done. I rather overpay for a VNT Turbo then a door hinge.
Post #1076929 6th Oct 2025 5:53am
Mo Murphy
Except, Defendercan, that an expensive set of fancy new hinges is cheaper than having to replace a later model door assembly ! Theft of doors in the UK is a problem.
I used SC Engineering hinges which prevent access to any of the bolts.
https://ebay.us/m/bKePz7
50 Shades of Pennine Grey
Post #1076946 6th Oct 2025 12:04pm
Stacey007
My passenger lower hinge has dropped a bit when opening the door. Its been like this for 18months,
I have just bought a replacement std one and I will spray it, I cannot see on a 110 the after market kits being 'worth' £700 plus? If the one I have is OEM then its lasted 16 years.
If this one lasts 16 years then all good.
Thumbs Up
Post #1076956 6th Oct 2025 1:43pm
