Home > Maintenance & Modifications > Which hinges?
Which hinges?
Britpart
0%
 0%  [0]
Bearmach
4%
 4%  [3]
SP4x4
4%
 4%  [3]
Land Rover
31%
 31%  [21]
Optimill
36%
 36%  [24]
Croytec
7%
 7%  [5]
Other...
15%
 15%  [10]
Total Votes: 66
Page 1 of 4 1234>
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Which hinges?
I've had a trawl through the history of this section but not yet found a thread about the pros & cons of various door hinges. I only really need a pair for the driver's door, but if I go non-standard it'll nag me to replace all 8... (DCPU).
Normal steel, stainless steel, anodised aluminium???
Clearly its possible to spend anything from Ģ8 to Ģ75 on a single hinge, but are the cheap ones really awful and are the expensive ones really great?
Thanks
John
Post #606902 5th Mar 2017 1:39pm
Snorkers
Scotland 2007 Defender 110 Puma 2.4 HT Keswick Green
I've recently replaced the rear door hinges on my 110. The safari door that carries the spare. I stumped up for the stainless hinges from YRM in the hope that I'll not have to replace them again anytime soon. Whilst they are expensive, the quality is absolutely faultless!
Whilst I don't like wasting money, its nice when you buy something that exceeds your expectations
I know that might be a bit 'blingy' for some but if it's a choice between shiny or broken with rust streaks ill take stainless every time. I tried to justify the price by telling myself that the cost of standard hinges plus primer, paint and lacquer would soon add up! Ha Ha. I know - I'm deluded.
Strikers
Post #606905 5th Mar 2017 2:10pm
ericvv
One of the 5 non LR suppliers in your poll who position themselves as a quality parts supplier once answered an e-mail request about quality of their hinges as below. I took this from another forum.
hi xxxxxx,
they are actually allmakes hinges but are of similar quality to brtipart as they all use the same type of hinges, they are very good for the money but if you want the best you need to buy genuine land rover ones but they do cost about 4-5 times the price
kind regards
If I ever have to replace my front hinges, I will take their advise and just use ACF-50 on the hinge pins from day 1 in the hope that this will prevent any rust from developing. (I have a very minor rust problem at the front door hinge pins now, but with regular use of ACF-50 it does not seem to get any worse)
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #606907 5th Mar 2017 2:12pm
I'm waiting for the Gore security hinges, which, if they live up to expectations, will be clear winners.
Post #606908 5th Mar 2017 2:20pm
Intercept
For me, price ignored, the only problem with the Gore stuff is the GORE writing. Not so bad on a fuel filter housing, but the writing on the bonnet hinges looks awful. I fear that the door hinges would be similar. Maybe they'd delete a few commands from the CNC file for me and make a set without the hideous branding?
Post #606921 5th Mar 2017 3:31pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Like blackwolf I shall be waiting to see what Gore has to offer, have been in contact with Dave at Gore and all he could say was that he cannot publish pictures of the hinges yet due to his waiting for the ok from his patent attorney, but he did write in his email
"None of the bolts will be accessible from the outside of the car once the hinge is fully fitted.
The bolts supplied will be stainless steel cap heads"
Paul. Cogito ergo sum
Post #606923 5th Mar 2017 3:44pm
Paul55
You can choose if you want the Gore logo on the window or bonnet fittings Thumbs Up Cogito ergo sum
Post #606924 5th Mar 2017 3:46pm
Intercept
Quote:
You can choose wether you want the Gore logo on the window or bonnet fittings
That's good to know - thanks Paul55
Post #606946 5th Mar 2017 5:14pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I have optimil front door and back door hinges and gore (non logo) bonnet and windscreen
Optimil hinges second to none on the market at present
I think the Gore hinges will be equal quality but I wanted front and rear to match so went with the optimil ones
I hope this helps 😊👍 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #606961 5th Mar 2017 5:47pm
Intercept
Are the Gore products available with a black anodised finish?
Post #607091 5th Mar 2017 10:32pm
Paul55
Yup,
http://goreproducts.com/
Paul Cogito ergo sum
Post #607093 5th Mar 2017 10:38pm
mk1collector
I'm also waiting on the gore ones but the Croytec ones have a built in grease nipple so can be maintained better. Ray
My build thread
Post #607106 5th Mar 2017 11:23pm
zsd-puma
I'm waiting on the Gore ones too, i've already got their (non logo'd black) bonnet hinges and they're superb. They also appear to be a lot more difficult to undo than all the other so called "security hinges".
Post #607118 5th Mar 2017 11:39pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I too decided to go the Optimill route, for bonnet, door and rear door hinges. The original (only five years young) LR door hinges, despite regular doses of grease and Ballistol occassionally produce rusty trail, and the play in the lower driverīs door hinge is considerable. Once I have freshly recoated door mirror arms prepared, I shall spend a pleasent afternoon fitting the full set. Very impressed with the quick turnaround and email contact at Optimill. The parts are beautifully packaged and presented. The technical design is quite clever. However they do not have grease nippels like the croytec oneīs.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #607124 5th Mar 2017 11:53pm
shaggydog
At the other end of the market...
I bought a set for 4 doors from Foundry 4x4 which were galvanised.
Still working fine and a good price.
Just make sure you go for the later Td5 versions as the early ones are terrible. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #607225 6th Mar 2017 2:26pm
Page 1 of 4 1234>
