Home > Puma (Tdci) > Help needed – Defender TD4 stopped after VCV replacement
Page 2 of 2 <12
irishhawk11 wrote:
--> Is it possible the the pressure valve released? I read that this needs to be replaced when the valve is triggered.
Yes, it is possible for the PRV to pop and the valve does not reset once popped. A popped valve is always always a consequence of a faulty VCV (remember that the VCV is the control for the fuel rail pressure) but most VCV fault do not cause the PRV to pop. If the PRV has popped the according to LR the entire fuel rail must be replaced, but aftermarket PRVs are available and it is possible to replace just the valve. However I don't think that this is what is happening in your case since the error code specifically reports that there is a fault with the fuel rail pressure sensor (the thing at the opposite end of the rail to the PRV) circuit, it is not reporting that there is no (or low) fuel rail pressure, which is what it would be doing in the case of a popped PRV. If you are going to randomly replace something you are probably better off replacing the sensor than the valve.
irishhawk11 wrote:
--> or could this failure be because I opened them middle valve of the fuel rail to check if fuel is coming, which wasn't the case...?
Unlikely unless whilst doing this you did collateral damage to something else. The centre union (and I presume you mean union and not valve) is the supply line from the HP stage of the pump into the rail and whilst loosening this will cause the rail to lose pressure and could conceivably allow air to enter the rail, the rail will self-bleed via the fuel return circuit. Remember that there is no need and no procedure for bleeding the HP circuit, only the LP circuit.
The P019015 error code ("Fuel rail pressure sensor A circuit - circuit short to battery or open") is very specific and points to an electrical fault not a fuel rail pressure fault. The lack of pressure is a consequence not the cause.
Post #1071111 9th Jul 2025 3:31pm
irishhawk11
Austria 2011 Defender 90 Puma 2.4 HT Santorini Black
What u think regarding the fuelrail pressure when trying to start?
i bled the fuel system and some air has come out but not a lot...
Post #1071130 9th Jul 2025 4:56pm
andy63
If I'm reading that correctly there is no high pressure.. 250kpa is between 2 and 3 bar..you would need to see something approaching 200bar for the injectors to fire..
Post #1071135 9th Jul 2025 6:49pm
The DTC is pointing to a problem with the pressure sensor so it is very unlikely you'll get sensible and correct readings.
As stated several times now you need to establish that the ECM is getting sensible measurements from the sensor.
Post #1071155 9th Jul 2025 10:33pm
irishhawk11
Here a short video of the starting problem:
https://youtube.com/shorts/zi_O3sJ7px4?si=n9ZkaMiOSCsDI26y
Post #1071158 9th Jul 2025 11:25pm
jst
Have you checked the engine loom to vehicle loom connector at the rear right of the engine, it would be behind the vcv and area younwere working in. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1071172 10th Jul 2025 10:22am
irishhawk11
Current Status
Hello Guys,
I just want to give you a brief update of my current situation.
What I have done:
-Replaced the VCV with now third one, a Denso VCV with positioning pins --> Problem remains
-Replaced the Fuel-Pressure-Valve --> Problem remains
-Checked the CPK-Sensor --> Engine Rpm available therefore failure can be excluded.
Checked voltages:
-Starter battery is done but still doesn't want to start with jump leads.
-Error code P019015 only exists when the Fuel-Pressure-Sensor is unplugged, therefor I don't think this is the issue.
I have now brought the Defender into an offroad workshop and will get news shortly. I will let you know ASAP.
Regards
Ben, a sad td4 owner[/list]
Post #1071887 21st Jul 2025 12:25pm
So you actually haven't yet done what has now been suggested several times and investigate why you have an electrical fault in the pressure sensor circuit! Rolling Eyes
Good luck, looking forward to hearing what the problem turns out to be.
Post #1071891 21st Jul 2025 1:00pm
irishhawk11
Hello again,
the error-message only should up when unplugged, otherwise the error-didn't appear.
Yes, its hopefully not a financial ruin topic.
Regards
Post #1071920 21st Jul 2025 5:04pm
Yes, I'm afraid I missed that absolutely crucial piece of information which only came to light halfway down page 2 of the thread!
We'll still be interested to hear what your specialist comes up with and, as you say, hopefully it won't be major.
Post #1071926 21st Jul 2025 5:56pm
Page 2 of 2 <12
