![]() | Home > Puma (Tdci) > Help needed – Defender TD4 stopped after VCV replacement |
irishhawk11 Member Since: 07 Mar 2022 Location: Feldkirch Posts: 21 ![]() ![]() ![]() |
What u think regarding the fuelrail pressure when trying to start?
![]() Click image to enlarge i bled the fuel system and some air has come out but not a lot... |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 785 ![]() ![]() |
If I'm reading that correctly there is no high pressure.. 250kpa is between 2 and 3 bar..you would need to see something approaching 200bar for the injectors to fire..
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17853 ![]() ![]() ![]() |
The DTC is pointing to a problem with the pressure sensor so it is very unlikely you'll get sensible and correct readings.
As stated several times now you need to establish that the ECM is getting sensible measurements from the sensor. |
Here a short video of the starting problem:
https://youtube.com/shorts/zi_O3sJ7px4?si=n9ZkaMiOSCsDI26y |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8321 ![]() ![]() ![]() |
Have you checked the engine loom to vehicle loom connector at the rear right of the engine, it would be behind the vcv and area younwere working in. Cheers
