Home > In Car Electronics > The definitive Defender ICE thread
Page 71 of 72 <123 ... 707172>
Reverse camera trigger is reverse line live +
Purple / white trace.
It’s a good idea to fuse at about 100mA in-line just inside the vehicle from the reverse, so if there was a short you’d still keep your reverse light active, but protect downstream from there.
The light green is parking brake aka handbrake live + line trigger, for this a parking brake module is a good idea to avoid cutting into existing wiring.
The trigger for these things will be the ISO side that is primary power, speakers if used are on their own dedicated side for speakers only if used.
So ground, ignition, permanent 12v, illumination, 12v rmt blue/white, revere trigger, etc will be on the primary power side, the speakers are on the other side.
The cleanest signal you’ll get is RCA out though, not speakers, and those RCA lines then can go to a passive Amp set up, but that is a full external audio install.
You’ll normally only get upto 50wrms max per channel from the HU itself, and will run hotter, 30wrms to 50wrms is typical.
If you have a 2.2 Puma you can always manually retrofit DIN ISO connectors to match the 2.4, which cuts down adaptors needed, you can simply follow a generic wiring diagram and plugs, pins etc are readily available.
DIN ISO, is aftermarket industry standard, most cars have an adaptor you can that converts to this.
2.4 Puma has it as standard.
All you’d need is a basic uninsulated crimp tool, generic din iso wiring diagram, Male plugs DIN ISO, and pins.
You can use a plug and play adaptor, but you do have the little extra bulk of the housings, the female connectors have a bit more bulk to them. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1058326 23rd Jan 2025 2:23pm
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Thanks for the in-depth reply Custom.
Re the Purple and white, nope, didn't do anything and isn’t labeled Camera or trigger, how ever the incorrectly coloured green and white trace did work. As per the attached photos, the loom doesn’t match the instruction diagrams.
Re the fuse, I always fuse immediately off any power supply. I’ll see if I can find the suitable connector block that the Rear Camera In RCA plug is connected to and only run that line to remove the extraneous audio cables, if not I’ll see if I can de pin the block vs cutting the lines. I live rurally so a definitive supply place in Cairns Australia is 100kms away.
Thanks again for the great reply.
Ken👍
 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #1058396 24th Jan 2025 12:25am
I see what you mean, it might be the I.D. Heatshrink / tag has been put on the wrong wire colour when made, and then put in the wrong pin housing on the block.
Then they matched the tag to the pin location but not the wire colour. Rolling Eyes
You can get keys to unpin, that is what I’d do too, what a pain.
If you can heat the shrink you can likely slide it off, if it’s adhesive a bit more tricky, worse case very carefully slit it along its length, put it where it should be and a little clear over the top to keep it in place.
Or a PVC adhesive electrical tape, fashioned into a flag, and you can write on it with a sharpie.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1058495 24th Jan 2025 7:43pm
Baytown
Good on you mate, I’ve a Dymo that I can label with and routinely mark my cables with. I should invest in a heat shrink labeller, that would be great. I’ve a set of de pinning keys - pins here so will see if they're suitable, although its a pretty small pin access.
I’ll post what my outcome is.👍 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #1058520 25th Jan 2025 1:15am
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1058587 25th Jan 2025 7:49pm
Baytown
I de pinned the connector
As discussed, I de pinned the speaker connector so that only the ‘Camera In’ line is connected vs the spaghetti mess involved with connecting the cable with the un needed RCA plugs and three other cables.
Removing the individual cables was easier than expected, just requiring lifting the tiny plastic tabs and pulling the cables out. Best part is it should be easy to reassemble the loom if needed in the future should I fit an external amp. That will make the cable clutter behind the AV unit a little easier to manage.👍
Post #1058849 29th Jan 2025 5:40am
Good work. Thumbs Up
Yes, reducing bulk of wiring behind there is a good idea, also any longer wires, it’s a good idea to secure and protect them within reason so they don’t get stuck in or around the heater controls as they can get jammed up, not only stop them being operated but damaging the wires too. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1058912 29th Jan 2025 7:44pm
scottbraun5
United States
2020 Defender 110 radio doesn't work after fuse-check
Okay, so I was troubleshooting problem "A", and in doing so, I thought I would check the load space fuses. It was dark and they are hard to read, so I checked them all. I think I made something in the entertainment system get screwed up. Suddenly, I can't select and play the radio. I cannot play spotify on carplay, I can't attach a phone to bluetooth. Everything in the media section, the left on the front display dashboard, doesn't work.
Any idea on what is locked up? I've reset the pivy. navigation works. I can't make any sound come out of the system at all. When I try to play carplay on my phone, spotify will not play, so the software knows it can't make sound.
This is on a Defender 2020 110.
FYI, it turns out, since it was dark and there is no fusebox map for the "FL" fuses, I put the fuse back in the wrong place. My problem is resolved.
The discovery is people can reset their amp and maybe fix some of their volume knob silence problems by using FL13 or FL17 to reset the amp. I don't recall the number, but there is only one fuse there.
Thanks for any advice.
Scott
Post #1071053 8th Jul 2025 11:14pm
Scott - Which vehicle is this in and system / HU fitted? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071146 9th Jul 2025 9:19pm
Mago
Germany
Hi,
I'd like to install some new/improved speakers in my TD5; the old ones are simply worn out.
It´s a 90, I just need them in the front.
I've read a lot of good things about the Focal PS 130 FE, especially with the two tweeters on the dashboard. Unfortunately, I can't find a dealer who still has them in stock or can source them with any certainty.
So my question is: Is there a good and recommendable alternative?
I'd appreciate any advice; maybe someone has had the same problem...
Thank you
Very Happy Defender 90 TD5
Defender 110 Puma 2.4
Post #1073238 12th Aug 2025 8:45pm
jonny
Do you have Aircon or not?
I had a look with a set of 13cm Focals and they wouldn't fit due to the air outlets not allowing larger speakers..
In the end I went with ESX SXE4.2C speakers (https://esxaudio.de/english/sxe4.2c.html) which fit well and were significantly cheaper than the 10cm Focals. They sound OK - bit 'bright' (but that could be my tweeter placement on the dash), but you are never going to get decent bass from such a tiny speaker...
Post #1073240 12th Aug 2025 8:57pm
Try asking / emailing BladeICE.
I have no connection to them, but they are quite good for sourcing stock, and can also import as well.
For example there might be some US stock that they could get in, and ship to you.
It depends on if the items are actually available, but I would try contacting them, mention exactly what you are looking for inc impedance, wattage, model no, etc etc. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073241 12th Aug 2025 9:01pm
Mago
Germany
There is no Aircon anymore.
I asked someone who had installed the 130mm Focals, and he said with minimal adjustments it would fit...
Thanks for the tip about BladeICE, I'll write to them.
Post #1073309 13th Aug 2025 8:28pm
Thumbs Up
130’s do fit, but just be very careful with measurements. On a RHD the passenger side is closer IIRC. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073314 13th Aug 2025 9:19pm
Mago
Germany
Nice, thanks for the info Smile
So, I'm still waiting for a response from BladeICE.
Meanwhile, a shop here in Germany recommended these two as alternatives:
GZTC130-2X:
https://www.caraudio24.de/Lautsprecher/Gro...35855.html
MPK 130.3
https://www.caraudio24.de/Lautsprecher/Her...44619.html
Neither of these seems to come with a mount for the tweeters to mount them on the dashboard...
Oh, and it's a LHD.
Lets wait for BladeICE...
Thanks and regards
Post #1073478 16th Aug 2025 10:04am
