![]() | Home > General & Technical (L663) > Does anyone know how to activate air quality sensor with gap |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 136 ![]() ![]() |
It can't be activated, as the air quality sensor is a hardware piece that requires both the three-zone climate control and the Cabin Air Purification Plus package. All cars with three-zone climate come with the air quality sensor and Cabin Air Purification Plus. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 55 ![]() ![]() |
The programming side using GAP IID tool is easy. But you need some hardware. The first is a pollution sensor instructions below. You will also need the Ionizer.
https://www.lrdefender.org/pollution_sensor-715.html AIR IONIZER NOTE: RHD vehicle is shown, LHD vehicle is similar. Control Components The air ionizer technology helps the well being of both driver and passengers. The air ionizer improves the air quality within the passenger compartment and can help reduce allergens, viruses, bacteria and odours. The air ionizer uses nano-sized charged water particles which decompose harmful substances to cleanse the air. The air ionizer can be switched ON or OFF through the climate settings on the FCDIM. The air ionizer is only connected to the left center face vent in the instrument panel. The air ionizer is connected to a power supply and a ground connection. The air ionizer operates when an electrical signal is received from the HVAC control module. |
MarcJennings777 Member Since: 14 Nov 2024 Location: Youngstown Ohio Posts: 2 ![]() ![]() |
Thank you. I was hoping it would be a simple activation. It looks like I won't be doing all that just to have it. I appreciate the info though!
Mukafuka Member Since: 28 Dec 2022 Location: New york Posts: 12 ![]() |
My vehicle is equipped with the the three zone system and the ionizer. I change the CCF for PM2.5 with the gap but can't view the particulate matter levels. Do you know of another setting that controls this? |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 128 ![]() ![]() |
How hard would it be to fit them. I thought the clearsight retrofit was beyond me but it was a piece of cake! |
Aulus Member Since: 24 Nov 2024 Location: Connecticut Posts: 20 ![]() ![]() |
Not trying to necro this thread but here's what I've been able to figure out just now.
It's pretty easy to swap out the sensor, you can take the bottom shield off and snake your hand underneath and take it out(if you have small hands) For reference I have the ionizer 3 climate control and advance filtration. While the AQI will display it will not read the values and actually give you an AQI numbers. I believe the sensor is suppose to be one that does everything. Ambient airpollution etc, as this is what the listing says for the dealer. That being said I have an early 2021 so it's possible they only had the temperature sensor. I will buy a new sensor and let you guys know what happens. Disclaimer* enable the multican-752 w/o the sensor will take away your ability to manual hit purify. Sounds like it's suppose to do it automatically but without the values it won't turn itself on." Also I'm not sure the difference between the ionizer and the purifier and I was under the impression the purifier is just a recirculate on the cabin air filter. Enable to: 1.Eucd-150 2. The ionizer one 3. Multican-752 " enhanced particulate filter and sensor, and soft button fitted (mine was fitted, w/o sensor) 4.AQI button or something - fitted (mine was not fitted) |
I look forward to your next instalment!!
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 185 ![]() ![]() |
hello, do not buy a new air quality sensor, it is not needed to display pm2.5 and co2, to have this function you must install two other new sensors, one inside the passenger compartment and one near the fuses in the engine compartment.
I have already done the tetrofit of the ionizer and pollution sensor, pm 2.5 filter, soon I will also install the two new sensors, in the meantime I will send you a couple of photographs. Marco ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Perfect!
Any chance you have the part numbers for the other two sensors? I did take a quick look for the sensors, I don't have the additional two unfortunately, it didn't seem like I have loose connectors. I wonder if it's a different wire harness. |
hello, these are the part numbers, LR
179197,LR174140,LR174153, LR174155, sensor and bracket, the advanced air quality system is only available on defender from 2024, the wiring is not present, however it is quite simple to make if you have skills, you also need to buy the two sensor connectors with the relative pins, the electrical wires of the appropriate colors, connect according to the original wiring diagram and do the programming with gap. if you want to do the work, write to private and I will forward you the wiring diagrams for the retrofit. Marco |
MJGillette Member Since: 04 Sep 2025 Location: Hawaii Posts: 3 ![]() ![]() |
That sounds Great. Thank you for the info. I just bought a 2024 V8 SE and I'm trying to retrofit everything that I don't have from the regular V8. I just joined this forum and don't have the permissions to PM you yet. I would love the wiring diagrams and any other info on the air quality/pollution sensors/ionization sensors I would need to retrofit that functionality. Thank you!!
Hi, sorry, I can't make any other documents public beyond what I've already published. I don't want to harm the work of some professionals. Due to the regulations, I don't think I can publish my email address. You have to write "OK" and I'll help you with the retrofit. Marco
OK. Thank you for your help!!!!
Hopefully it will let me PM now.
