Home > Modifications & Maintenance (L663) > Anyone fitted a split charge dual battery
Page 5 of 5 <12345
Mark1107
United States
Ok, to camp or greenlaning,
We sleep in the back on camping trips. I disabled the vehicle waking up and the lights coming on or off with solely the tailgate/boot door opening and closing. Now for my regular contributions to the forums:
Multican 703 “BCM interior light trunk” Fitted.
Multican 703 BCMinterior light delay” Fitted. Immediately turns out all vehicle lights without a 30 second delay.
So the 1st one stops ALL vehicle lights when trunk/boot door is opened or shut.
The 2nd one immediately stops the lights when any of the 4 passenger doors are opened because our vehicles are set for a 30 second delay which drains the battery. 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1033917 6th May 2024 12:25am
Cheshire110
Anyone on here have success running a cable from the battery (under front seat) to under the boot floor? Can't believe how tricky it's turning out! Cheers, David
Post #1069266 7th Jun 2025 8:06pm
Cheshire110
In case it's helpful, here's what I came up with over the last 24 hours...
I've not fitted a dual battery system strictly, but I have fitted a Renogy 1000W inverter off a ignition-switched relay under the boot floor, so that I can then charge my EcoFlow 0.5kWh battery pack and run fridges, laptops, etc.
I ran a cable from the battery (under driver seat) to the rear, underneath the foam boot floor insert, and there I connected it to a mega-fuse block with 80A fuse and a switched relay.
You can get an ignition feed to switch the relay from the blue and green wire which goes into the connector for the deployable rear tow bar.
My inverter then sits inside the foam with wired routed through a small access window that I cut myself for ease.
For now I've just got the inverter sat in there loose, with an extension cable and the CAT-5 cable to the remote panel wiggling their way up above the boot floor
In the future I might build myself a more custom under-boot panel and storage area out of ply, but that's one for another day.
I also need to find a neater permanent way to route the battery cable - it's much harder than you'd think to get a cable under the rubber flooring so for now it's just underneath the rubber mats... Suggestions welcome!
 Cheers, David
Post #1069316 8th Jun 2025 7:09pm
Defendit..
Netherlands
@cheshire110
Routing under the rubber flooring, very tight. You may need to remove the rear seating frame.
2nd picture on this:
https://www.defender2.net/forum/topic87513.html No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1069338 9th Jun 2025 9:31am
Navkol
Poland
So here is my power upgrade: dual battery + solar + couple of more controls Cool
I can't upload the *.pdf file I've created, so if anyone is interested - shoot me the PM.
Sample pictures (3):
Post #1071714 19th Jul 2025 4:10am
Page 5 of 5 <12345
