Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 110 of 111 <123 ... 109110111>
CMG
Germany
This definitely is what my car does as well. Maybe there are different versions about? Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1064615 3rd Apr 2025 6:57pm
Mouta
United Arab Emirates
Adamalli wrote:
I have also been able to enable the Dynamic Driving Mode and the Dynamic-I Setting icon, advance tow assist, and 007 startup screen.
I already have the wifi hot spot, though I think i found the setting for that, and terrian response 2.
What I would really like is adaptive cruise control. I found the setting for this and when enabling it I get the distance setting buttons to light up, but get an error about emergency breaking not working. When viewing the faults for the vehicle there is a fault for the ABS. I haven't figured out how to get past this.
Does anyone know how/if there is a way to export your current cars CCF. I would like to keep track of what I am doing in a spreadsheet but for the life of me can't see a way to export the current CCF.
Over on landroverforums.com there is a guy that has figured out how to activate a lot of items, though he uses the official diagnostic tool and pathfinder software. He charges for his services, which I am sure is worth it to some people and those who want things now. I like to tinker so don't mind trying to figure things out myself. Point being is the list below is what I think we should be able to figure out as a group at some point.
1. wifi hotspot.
2. Last user mode disables stop start on p300 defenders permanetly on or off with the simple touch of a button even after ignition cycles.
3. Adaptive cruise control with que assist including full stop and go.
4. Adaptive speed limiter.
5. Adaptive high beams with configurable settings.
6. Advanced off road package.
7. All terrain prgress control & configurable terrain response!
8. On demand center locking differential with the touch of a button.
9. Global window close from your key fob.
10. Global window open from your key fob.
11. Sunroof open from your key fob.
12. Sunroof close from your key fob.
13. Tailgate pop open from your key fob.
14. Bright Lights/High beams on with your fog lights on. (Not allowed in North America buyt we do it)
15A. Configurable dynamic mode (Even the V8 and/or 007 Defenders dont have this!)
15B. Proximity locking & unlocking works on some model years.
16. Dynamic mode- controls throttle, suspension, steering, braking settings.
17. Timers and G force meters on the navigation system.
18. DAB radio and XM radio activation. (Needs a subscription eventually.)
19. Engine noise cancellation.
20 Engine sounds through the speakers disabled.
21. Cell Phone signal boosting.
22. Advanced Tow assist.
23. Activity Key as long as you have the correct MHZ frequency key.
24. Needs hardware! Adding center console fridge freezer.
25. Needs professional installation and wiring then we can activate the rear differential as an oem add on after the fact. Yes fully OEM with the advanced off road pack after you buy the oem parts and have them professionally installed we can activate the differential to be fully oem integrated.
26. 12.3 inch Navigation center console upgraded AFTER you buy and have installed the 12.3 inch screen we can activate it.
Primarily interested in "21. Cell Phone Signal Boosting" - has anyone successfully obtained the necessary CCF modification for this?
Post #1064977 8th Apr 2025 10:39am
Fifth Horseman
Cellphone signal boosting needs additional hardware, specifically:
1 - wireless charger module (has integral antenna coupler)
2 - the top of the centre console needs modifying or replacing to fit the charger module
3 - RF amplifier module
4 - external antenna, fits behind LH rear light trim
Generally if this is not fitted from factory the wiring is not present so adding this is not just the trivial exercise of changing "MultiCAN-854 Phone Signal Booster" Defender 110 D300 X-Dynamic HSE MY22
Defender 110 Station Wagon 2011 (gone)
Defender 110 DCPU 2007 (gone)
Post #1064995 8th Apr 2025 1:51pm
Mouta
Really appreciate the quick and detailed reply! Thumbs Up
Post #1065372 13th Apr 2025 6:06am
Mouta
We’re all pretty used to the Defender’s noisy cabin by now, but I’m curious if there’s a way to modify any CCF settings to enable something like Speed-Sensitive Volume Control which automatically adjusts audio volume based on the vehicle’s speed to compensate for road and wind noise. That would be a treat!
Post #1065548 15th Apr 2025 8:41am
Mouta
My 24MY DEF130 came with the Driver Assistance Mode factory fitted, but both Speed Limit Warning and New Speed Limit Notifications seem to be missing. Is there a way to enable these features by tweaking the CCF settings?
Post #1066110 23rd Apr 2025 7:43am
Colin68
Don't do it as they are so annoying and you have to turn them off every time you start your car!
Post #1066113 23rd Apr 2025 7:47am
Mouta
Oops, I guess I'm better off then. Thank you!
Post #1066114 23rd Apr 2025 7:49am
Mouta
Just thinking out loud, from what I understand, Custom mode retains the settings for Speed Limit Warning and New Speed Limit Notification, which is actually quite useful in certain areas.
But to prevent Driver Assistance from defaulting back to High, you could adjust the CCF as follows:
MultiCAN-889 GSR2 EU Market Ft → set to Non GSR2 Country
Wouldn’t that let me enable both features while also avoiding the constant reset? Seems like a win-win!
Post #1066201 24th Apr 2025 5:47am
Flo1610
Germany
Can someone provide me with his CCF files of a Defender MJ24 delivered in Germany, of course without VIN and personal data Wink I'm trying to find a fault with my vehicle and would like to compare the data. It would be great if someone could send me the CCF.
THANK YOU, greetings Flo Defender 110 XS, MY24, D250 Santurini Black
Post #1066677 30th Apr 2025 10:18am
QuintusJM
South Africa
Incorrect post
Post #1066887 2nd May 2025 7:14pm
QuintusJM
South Africa
Hi all,
I’m in South Africa and my Defender didn’t come with traffic sign recognition activated. I also don’t see an option to show the speed limit for the road I’m on in the navigator screen.
I managed to get traffic sign recognition to work and it does show the speed limit for the road I’m on, but was wondering if it’s possible to show on maps as well? Theoretically should be possible as some of my other vehicles that also has Here maps does show the speed limit.
Also saw under EUCD-247 Offroad navigation that there is an option to specify Offroad navigation fitted. Does anyone know what this doe perhapss?
Post #1066888 2nd May 2025 7:14pm
DMC3157
United States
Is there a comprehensive List of working CCF Modifications? Maybe a Google sheet? If not there should be... This is tough to follow after a 109 pages of different posts.
Post #1067044 5th May 2025 5:41am
Mouta
It’s supposed to be available here: https://www.defender2.net/forum/topic89347.html
Yet it’s still missing all the working CCF mods.
Post #1067045 5th May 2025 5:45am
Mouta
QuintusJM wrote:
Hi all,
Mind sharing which mods you used to enable traffic sign recognition? I haven’t messed with EUCD-247 before or even come across it.
Post #1067046 5th May 2025 5:47am
