![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Mouta Member Since: 24 Mar 2025 Location: Abu Dhabi Posts: 33 ![]() ![]() |
Primarily interested in "21. Cell Phone Signal Boosting" - has anyone successfully obtained the necessary CCF modification for this? |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
Cellphone signal boosting needs additional hardware, specifically:
1 - wireless charger module (has integral antenna coupler) 2 - the top of the centre console needs modifying or replacing to fit the charger module 3 - RF amplifier module 4 - external antenna, fits behind LH rear light trim Generally if this is not fitted from factory the wiring is not present so adding this is not just the trivial exercise of changing "MultiCAN-854 Phone Signal Booster" Defender 110 D300 X-Dynamic HSE MY22 Defender 110 Station Wagon 2011 (gone) Defender 110 DCPU 2007 (gone) |
Really appreciate the quick and detailed reply!
We’re all pretty used to the Defender’s noisy cabin by now, but I’m curious if there’s a way to modify any CCF settings to enable something like Speed-Sensitive Volume Control which automatically adjusts audio volume based on the vehicle’s speed to compensate for road and wind noise. That would be a treat!
My 24MY DEF130 came with the Driver Assistance Mode factory fitted, but both Speed Limit Warning and New Speed Limit Notifications seem to be missing. Is there a way to enable these features by tweaking the CCF settings? |
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 120 ![]() ![]() |
Don't do it as they are so annoying and you have to turn them off every time you start your car!
Oops, I guess I'm better off then. Thank you!
Just thinking out loud, from what I understand, Custom mode retains the settings for Speed Limit Warning and New Speed Limit Notification, which is actually quite useful in certain areas. But to prevent Driver Assistance from defaulting back to High, you could adjust the CCF as follows: MultiCAN-889 GSR2 EU Market Ft → set to Non GSR2 Country Wouldn’t that let me enable both features while also avoiding the constant reset? Seems like a win-win! Last edited by Mouta on 24th Apr 2025 6:39am. Edited 1 time in total |
Flo1610 Member Since: 15 May 2024 Location: Hessen Posts: 14 ![]() ![]() |
Can someone provide me with his CCF files of a Defender MJ24 delivered in Germany, of course without VIN and personal data
![]() THANK YOU, greetings Flo Defender 110 XS, MY24, D250 Santurini Black |
QuintusJM Member Since: 19 Apr 2025 Location: Johannesburg Posts: 3 ![]() ![]() |
Incorrect post
Hi all,
I’m in South Africa and my Defender didn’t come with traffic sign recognition activated. I also don’t see an option to show the speed limit for the road I’m on in the navigator screen. I managed to get traffic sign recognition to work and it does show the speed limit for the road I’m on, but was wondering if it’s possible to show on maps as well? Theoretically should be possible as some of my other vehicles that also has Here maps does show the speed limit. Also saw under EUCD-247 Offroad navigation that there is an option to specify Offroad navigation fitted. Does anyone know what this doe perhapss? |
DMC3157 Member Since: 05 May 2025 Location: Denver Posts: 1 ![]() ![]() |
Is there a comprehensive List of working CCF Modifications? Maybe a Google sheet? If not there should be... This is tough to follow after a 109 pages of different posts.
It’s supposed to be available here: https://www.defender2.net/forum/topic89347.html
Yet it’s still missing all the working CCF mods. |
Mind sharing which mods you used to enable traffic sign recognition? I haven’t messed with EUCD-247 before or even come across it. |
