Home > My Defender > Lizzy
Page 8 of 8 <12345678
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
As an addition to the Uproar4x4 front bumper I've fitted some front recovery points. Hopefully these will be only used for rescuing others and not for being pulled out of ditch. Scott from Uproar4x4 was very helpful making these for me. I believe they will now be part of his regular product line.
Post #1031610 15th Apr 2024 10:25am
JamieL
steveww wrote:
There has been a bit of a clonk / rattle from the rear of Lizzy when going down farm tracks. Something was obviously a bit loose somewhere. Finally tracked it down to the rear sliding windows; a well know issue with Defenders. I cut some cable ties to size and used them as packers to hold the sliding glass in place. I've ordered new felt channels top and bottom from LR Parts and these should be a more permanent fix when they eventually arrive.
Hello, what kit did you use for the felt channels, is there a part number? How difficult was it to fit the new runners?
Post #1066261 25th Apr 2025 11:11am
steveww
I looked up the part numbers from https://parts.jaguarlandroverclassic.com/p...and-rover/
They are a right pain to swap out. The new items are flat so they don't really want to go in the U shaped grove. A suction glass handler was a big help and a second pair of hands too.
Post #1066590 29th Apr 2025 10:02am
JamieL
Thanks for that, so I think I need CZL000020
Post #1066596 29th Apr 2025 12:05pm
