Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 109 of 112 <123 ... 108109 110111112>
rabalam
United States 2016 Defender 110 Other Experience LE Auto Santorini Black
@norland
Although we appreciate you responding to this thread, I am yet to see the value-add in your comment. This thread was to discuss how to get the sidebar working, but for some unknown reason you decided to interject your onion, which was not helpful ,nor asked. If in the near future you have any helpful technical information outside of your opinion we'd welcome that for sure.
Again thanks and regards,
Yours' Truly Those of Us Who Like Clutter..
Post #1061242 24th Feb 2025 6:24pm
mse
I quite like that shortcut tile, but do think the sidebar adds a bit of clutter. Do you need 1 to have the other? Mike
Post #1061246 24th Feb 2025 7:00pm
OVRLANDR
United States
No, you can choose what you would like as a soft key.
Post #1061286 24th Feb 2025 11:01pm
Sticks999
L663 EPB Service position. Gapi IID G4
Sorry complete tangent to the previous thread but does anyone know where to find and activate the service position on the GAP IID G4
Post #1061335 25th Feb 2025 4:20pm
DefenderMidlands
What do you mean by the service position? MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1061344 25th Feb 2025 5:05pm
Sticks999
When you change the rear break pads you need to put the caliper into service position to release them
Post #1061401 26th Feb 2025 8:13am
mse
You can do that without IDD
procedure requires the vehicle in the Park or Neutral position, with the ignition turned ON (the
engine must be OFF) and the parking brake system released.
Press and hold the parking brake switch in the release position.
Wait 2 seconds.
Press and hold the accelerator pedal in the wide open throttle position.
Wait 2 seconds.
Turn the ignition Off and back On immediately.
Release the accelerator pedal and release the parking brake switch to the neutral position. Mike
Post #1062179 6th Mar 2025 1:11pm
bijan0005
Hi,
I'm sorry that I'm posting not in relevant forum. I couldn't find solution anywhere else for a long time.
Has anyone encountered with "TSR and ASL not supported in this country" issue ? Range Rover Sport SDV6 2020 was imported from South Korea, now in Uzbekistan. Navigation maps were for South Korea region, TSR and ASL were working fine. But after installing Europe maps, start the car and after 20 seconds it finds the satellites, TSR sign disappear in IPC and HUD, and in menu it shows that "TSR and ASL not supported in this country"
Is there any CCF parameter which can be modified to solve this issue ?
Checked several Land rover cars in my region, and cars imported from Europe with Europe maps have TSR and ASL working fine.
Post #1062347 8th Mar 2025 8:19am
AlistairS
United Kingdom 2016 Defender 110 2.5 TD Adventure Scotia Grey
Thank you for posting this. Does the heating dial pop up when you use the Advanced Tow Assist? I ask as I am confused as to whether specific hardware is needed, or whether all Defenders have the required hardware.
Post #1063472 21st Mar 2025 12:31am
CMG
Germany
Hello Guys, I have a MY2024 D250 SE, and I have a GAP tool G4. I have a question which may be unusual. My car has Adaptive Cruise Control, and I would like to get rid of this. Have not seen this to be discussed here already, only the opposite thing. I find it to be a useless, stupid feature. I dislike all kinds of things which cause the car to dictate certain behaviours, overriding the driver. The Adaptive Cruise Control is such a feature.
So - is it possible to deactivate Adaptive Cruise Control, but keep the standard version of this feature active? Thanks for any help on how to do this. Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1064563 3rd Apr 2025 10:50am
Retroanaconda
You can just turn it off with the controls on the steering wheel, no need for the IIDTool. It then just works as normal cruise control.
Post #1064606 3rd Apr 2025 6:36pm
CMG
Germany
Thanks. Yes, I am aware of that. I have de-activated it a couple of hundred times, in the past months, and I am looking for a more intelligent solution. Thumbs Up Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1064607 3rd Apr 2025 6:39pm
Retroanaconda
Weird, if I set mine to normal cruise it stays that way - no need to do it again. There’s no need to be rude.
Nevertheless, these are the CCF settings for ACC. If you set them to not fitted as appropriate it will probably disappear.
Post #1064608 3rd Apr 2025 6:46pm
CMG
Germany
That actually is quite interesting. I was not aware that this function has a memory, I shall look at that. My feeling is that I have and had to re-deactivate it all the time. But, also, many thanks for your GAP Tool suggestion. I will implement that. Thumbs Up Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey.
Post #1064610 3rd Apr 2025 6:52pm
pjeski
United States
CMG wrote:
That actually is quite interesting. I was not aware that this function has a memory, I shall look at that. My feeling is that I have and had to re-deactivate it alle the time. But, also, many thanks for your GAP Tool suggestion. I will implement that. Thumbs Up
I don't know how others work, but mine always reverts to the 3 bar setting on restart. I'd like to know if there is a setting that will make it remember where I left it.
Post #1064613 3rd Apr 2025 6:56pm
