![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
I quite like that shortcut tile, but do think the sidebar adds a bit of clutter. Do you need 1 to have the other? Mike
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 45 ![]() ![]() |
No, you can choose what you would like as a soft key.
Sticks999 Member Since: 10 Sep 2024 Location: Durham Posts: 8 ![]() ![]() |
Sorry complete tangent to the previous thread but does anyone know where to find and activate the service position on the GAP IID G4
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 279 ![]() ![]() |
What do you mean by the service position? MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
When you change the rear break pads you need to put the caliper into service position to release them
You can do that without IDD
procedure requires the vehicle in the Park or Neutral position, with the ignition turned ON (the engine must be OFF) and the parking brake system released. Press and hold the parking brake switch in the release position. Wait 2 seconds. Press and hold the accelerator pedal in the wide open throttle position. Wait 2 seconds. Turn the ignition Off and back On immediately. Release the accelerator pedal and release the parking brake switch to the neutral position. Mike |
bijan0005 Member Since: 03 Feb 2024 Location: Tashkent Posts: 3 ![]() ![]() |
Hi,
I'm sorry that I'm posting not in relevant forum. I couldn't find solution anywhere else for a long time. Has anyone encountered with "TSR and ASL not supported in this country" issue ? Range Rover Sport SDV6 2020 was imported from South Korea, now in Uzbekistan. Navigation maps were for South Korea region, TSR and ASL were working fine. But after installing Europe maps, start the car and after 20 seconds it finds the satellites, TSR sign disappear in IPC and HUD, and in menu it shows that "TSR and ASL not supported in this country" Is there any CCF parameter which can be modified to solve this issue ? Checked several Land rover cars in my region, and cars imported from Europe with Europe maps have TSR and ASL working fine. ![]() |
AlistairS Member Since: 21 Mar 2025 Location: London Posts: 1 ![]() ![]() ![]() |
Thank you for posting this. Does the heating dial pop up when you use the Advanced Tow Assist? I ask as I am confused as to whether specific hardware is needed, or whether all Defenders have the required hardware.
CMG Member Since: 06 Oct 2024 Location: Near Hamburg Posts: 14 ![]() ![]() |
Hello Guys, I have a MY2024 D250 SE, and I have a GAP tool G4. I have a question which may be unusual. My car has Adaptive Cruise Control, and I would like to get rid of this. Have not seen this to be discussed here already, only the opposite thing. I find it to be a useless, stupid feature. I dislike all kinds of things which cause the car to dictate certain behaviours, overriding the driver. The Adaptive Cruise Control is such a feature.
So - is it possible to deactivate Adaptive Cruise Control, but keep the standard version of this feature active? Thanks for any help on how to do this. Ex D4 & D5, now Defender D250 SE 110, MY24, Eiger Grey. Last edited by CMG on 3rd Apr 2025 11:30am. Edited 2 times in total |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
You can just turn it off with the controls on the steering wheel, no need for the IIDTool. It then just works as normal cruise control.
Thanks. Yes, I am aware of that. I have de-activated it a couple of hundred times, in the past months, and I am looking for a more intelligent solution.
Weird, if I set mine to normal cruise it stays that way - no need to do it again. There’s no need to be rude.
Nevertheless, these are the CCF settings for ACC. If you set them to not fitted as appropriate it will probably disappear. ![]() Click image to enlarge |
That actually is quite interesting. I was not aware that this function has a memory, I shall look at that. My feeling is that I have and had to re-deactivate it all the time. But, also, many thanks for your GAP Tool suggestion. I will implement that.
![]() Last edited by CMG on 3rd Apr 2025 10:01pm. Edited 3 times in total |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 115 ![]() ![]() |
I don't know how others work, but mine always reverts to the 3 bar setting on restart. I'd like to know if there is a setting that will make it remember where I left it. |
